Ground connection for Q35 (PA3004) is pin 5. Pioneer schematics are not consistent with marking the ground connections with the bolded line everywhere. If that is what your question relates to. It messes with me every so often also . . .
There is perhaps another explanation for your question, a more in depth answer to "Where does ground go." "Ground" is a monolithic concept that many people think is just 'magically' 0 volts and 0Ω. It is commonly represented this way on schematics, by showing a connection to a chassis ground symbol. Reality is much more complicated. Ohm's Law functions everywhere, whenever current flows there
is a voltage drop. Sometimes it is so small it is unnoticeable, but when currents flow through common conductors they add and subtract and interact. There are high current return paths for high current circuits. The power supply has a common point that the power supply (ground) returns and Speaker output currents return to. There is another small signal 'ground' to consider, that path usually starts at the input jacks and follows the small signal along (in a daisy chain) through the boards that carry, shape and amplify the small (sometimes called 'line level') signals. Schematics almost never show those as separate wires. Design engineers have to consider the interaction of 'ground currents' when they design a chassis. There is a place on the chassis called a Star Ground. All the small signal 'ground' wires come together at a physical point as part of the Star ground. The high current ground return wires from the transformer, power supplies and speakers come together at a different point, as part of the Star ground. There is a low resistance connection between these two points that completes the Star ground. That is usually where the electrical connection to the chassis is physically made. The key concept here is that the high currents and small signal currents do not physically travel on the same wires, so they do not interact. This reduces noise and distortion.
Here is a picture of the Star ground on my SX-1050, the strap is between the main filter caps:
Hope that was what you meant by your question, and I did not confuse you with too much information. I do ramble on sometimes
EDIT: I see you modified your question while I was composing an answer
