Built like tanks.
Twenty20Man said:
I really want to know if the seller removed the jumpers on back as Bait.
I have found a Pioneer SX1250, SX727, SX838, SA608 at thrift stores.
SX-1250, fuse okay, minor clean up and works fine, probably could use a restoration to really sing
SX-727, fuse okay, could not get the thing to work but noticed the plugs were missing, replaced those and worked fine!
SX-828, fuse okay, plugs intact, some elbow grease to get it clean, works fine.
SA-608, Okay here also.
Having had the opportunity to compare these 4 units, people are right, Pioneers are built like TANKS! This might be functioning unit with missing plugs.
You can ask the seller to use audio cables in place of the plugs to see if they could get some sound. If seller says, "don't have audio cables..". Then they may be baiting...
Sau
