SX-950 In Protection ... maybe more issues SOLVED
q3 and q4 collector voltages ?
they need to match each other .
q5 base needs to be higher than emitter . i see they are both very low .
Double triple quadrouple checked the orientation - all good.
Re-measured Q3 and Q4 collector voltages. Maybe I was too many drinks in last night - but now they're both around 16V and change. About 0.3V apart.
And Q5's B is in fact lower than E. 1.2V compared to 2.7V which are both an order of magnitude off anyway ...
Q5 voltages don't change even with all 3 diodes lifted.
R25 is -5.3 from D8 and -3.9 into C5.
R18 measures 146K (in circuit).
q5 is PNP 2SA733 .
KSC2690AYS is NPN ... so there is the problem .
best go through any transistors you changed to be sure they are correct subs .
Replaced with a KSA992 ... CLICK! I must have gotten my Q5s confused between the power supply and the protection boards.
... Still have the dim lights issue. And haven't even attempted to see if it actually makes sound through the speakers. Nor have I measured any new pin voltages. BUT IT CLICKS!
did you put the other parts back ?
i knew q5 was reading a bit oddly . it doesn't make it easy from here when incorrect parts are installed .
Yeah, other parts back in. (And 13V Zener still in the 14V spot.) Lesson learned on my part - slow down and pay attention when making parts lists. Very nice work on your part figuring that out from afar.
Reminds me of the proctologist who went to auto mechanic school ... after he finished his final test, an engine rebuild, his instructor couldn't believe it. "Nice work," the instructor said, "and even more impressive ... you did the whole thing through the tail pipe!"
I just verified that it does pass sound to the speakers - tuned into an FM station, came in clear and strong through my bench Minimus 7s. In addition to the dimming indicator lights, it has a slight hum through the speakers when no inputs are selected and volume at minimum. It's currently turned on, Aux input, vol min, awaiting a solid DC offset reading.
Edit: DC offset is -26mV in R, -31mV in L. Jumps to -50mV when AUX input is de-selected (leaving no inputs selected).
Well, for the bright / dim light issue, I found a thread directly on the subject, and the following was the solution as suggested by @kramden so I too will give it a shot.
If you used a KSC2383 or equivalent for Q10 on the power supply (originally a 2SC869), try a 2N5551 instead.
For reference, here's my transistor BOM for the two circuit boards I have rebuilt (Power Supply AWR-101 and Protection Circuit AW-062):
Solved it - didn't have a 2N551 on hand, but I did have a spare KSC3503, so in it went. Lights now behave, and no more hum when no inputs are selected nor through headphones.
Probably time to take that KSC2383 out of the BOM at Q10 in the power supply.
So here's the final BOM so as not to confuse:
well done :thumbsup:
another thing to note . some have had troubles subbing q3 q4 on protect board . i seem to remember 2sc945 work properly . and are original numbers .KSC1845FTA might not work properly .
