Got an SX 950, and when I plugged it in, I had dimming and brightening of the lighting, as well as popping noise on the A speaker output. I found a blown cap on the EQ amp board, and recapped and replaced all transistors on that board. Before I went further I checked the numbers on the power board, after hearing that you have to start there for these units. Here are the numbers. Most are good from what I can see, however one is way out. I have purchased all recommended caps/transistors for the whole reciever as at some point I want to replace them all. However, I would like to fix the problem first, then tackle each board on it's own so that I do not cause problems that are new, without fixing the existing problem. Pin 15 is way out. These are all DC measurements. If I need to change to AC I can do it. Please let me know what you think.
2 &3=5.2v
4 & 5=13.5
6 & 7=50.4
8-9-10=35.9
11=27.7
12=0
13= -14
14= -54.1
15=5.1 (yes this one is positive, not negative)
Please let me know your thoughts. I purchased my replacements from another large thread that included a full parts list for caps and transistors. I have not purchased any of the Zener Diodes.
Thanks a ton for your help. Let me know if you want any other testing. Thanks Troy.
2 &3=5.2v
4 & 5=13.5
6 & 7=50.4
8-9-10=35.9
11=27.7
12=0
13= -14
14= -54.1
