Thanks. I changed back to micro clips so I can not hit anything else.First cover all but the very point of your probe with heatshrink or tape so it won't do again what we have all done in the past.
Pull Q6, it could be loading the regulator, then 6-way test it. Leave it out for now. Did you order more? I buy small transistors by 100 lots, they cost less and are on hand when I blow them up.
I would say Q2 and Q4 toasted, and may have taken ZD12 (13v) with them. The emitter of Q4 should be higher, but the emitter has to come up for the current supply for it. Replace ZD12 if you have one.
"Protection relay does not release" Actually the Protection relay pulls in when the unit comes out of protection, either at power up or after a fault clears. It releases when going into protection or at power off.
I will see what I have in stock. I need more transistors. I changed q2 and q4 with new units. I need a new q6 and the zd if I do not have one.
Thanks.
