Well I figured out that most of them boards will come out from the bottom without taking the whole front off of the radio, so I put most of the front back together tonight. I'm still waiting on a few parts (transistors to replace the 2sa726's, and my bass pot, for ex.) to come in so I can't completely reassemble it just yet.
Unfortunately this has not been a journey without peril, I put every set of screws in separate cubbies in a container as I took everything apart and then, while getting everything ready to work tonight I bumped the container knocking all of the screws onto the floor. However I had put some screws back into the holes they came out of so it was not as bad as I at first thought. I had a bunch of pictures of the front in various stages of breakdown so they went back together easier than I thought.
The really nerve racking part was trying to get the Dial String back in place and working properly, never messed with one of those before. That was very tedious but I think I got it done and the way to adjust this one is to just slide the pointer across the string as it is not glued in one place. So when I get the radio back working I should just be able to tune into a local station, get the signal strength and tuning meters maxed and then be able to move the pointer to its proper location, at least I hope it goes that well. I know, best laid plans of mice and men....
Now if I didn't break any wires from any of the boards, miss anything, or just generally screw something up, hopefully it will all work properly. Unfortunately I can't test anything as the replacement bass pot I had to order hasn't come in yet so I'll have to wait for any testing...
I'll post a few pictures a little later as that process (I take pictures on an iPad, have to get them into the proper jpeg format, move them to my windows desktop, and then upload them) takes a little time and I need a break for a little while....
