Since my last posting, I got out the magnifying glass to check orientation of all the transistors on all the visible boards (power supply, power amp, protection and phono boards). I adjusted the offset and bios, listened to some compressed tunes via an echo dot plumbed through the aux input (sounded good) for a while and at some point, fried the 14v zener again. I took a few days off before replacing the zener and all the transistors on the power board except for Q’s 2,4,6. The negative circuit has been rock solid through throughout this process.
Q1 and Q8 each had one pad missing and the corresponding traces had lifted. I watched a few youtube videos and cut a couple of legs from a pulled 2073, scraped the green from the subject traces and soldered in the legs. Doing that kind of repair on a vertical board is a bit of a pain. But, I am happy with how it turned out as both components appear to be stable.
Yesterday, I powered up and got reasonable voltages across the board, but, after some warm up, the lamp circuit started acting up and voltages moved up from the initial 5.8vdc to 11.9vdc. I set the offset, which was a rock stable 0vdc on both channels on the mV setting of the Fluke 117. Multi-turns make such a difference. The bios floats a bit, but, I set both channels at 20.5vdc. If I try to reduce it anymore, the meter jumps down to 18vdc. I played tunes through the aux again and likely fried the aux bulb on the front due to the pins 2&3 being at 10.8vdc. I have some replacements on the way and wanted to be sure that both channels were working.
Today, I got the following measurements after the unit was warmed up:
Pin 1 SB 0 vdc 0
Pin 2 SB 5.4 vdc 11.6
Pin 3 SB 5.4 vdc 11.6
Pin 4 SB 13.9 vdc 13.3
Pin 5 SB 13.9 vdc 13.3
Pin 6 SB 51.5 vdc 49.2
Pin 7 SB 51.5 vdc 49.2
Pin 8 SB 36.5 vdc 35.4
Pin 9 SB 36.5 vdc 35.4
Pin 10 SB 36.5 vdc 35.4
Pin 11 SB 28.0 vdc 27.3
Pin 12 SB 0 vdc 0
Pin 13 SB -13.5 vdc (13.4)
Pin 14 SB -51.5 vdc (51.3)
Pin 15 SB -19 vdc (19.0)
Pin 22 7.5 vac 8.1
Pin 23 7.5 vac 8.1
Pin 29 7.5 vac 8.1
VDC
B C E
Q1 49.8 64.9 49.25
Q3 14.3 49.6 13.7
Q5 36 39.7 35.4
Q7 27.9 34 27.3
Q8 13.9 26.4 13.3
Q9 6.1 26.4 11.2
Q10 6.4 26.4 6.1
Q1-Q8 seem to be functioning properly, although they all seem to be just a little off spec - mostly a little low. I don’t know enough about transistors to speculate on what is going on at the collector junction of Q9 and Q10 - but I see it is a problem. I’ve changed Q9 and Q10 a few times now and I seem to have the same issue of inconsistent voltage at Pins 2&3 each time. Should I pull and test any of the upstream components? I replaced all the diodes and caps on this board when I started the project a few weeks back.
Another thing to note - Q9 emitter voltage (and thus pins 2&3) tends to wander as the unit warms up. i.e. it might be 5.8vdc at startup and slowly move up to 14vdc. And when it is high, it might start falling back. I listened through headphones, for about 15 min (I don’t want to fry the speaker lamp), before taking the above measurements. I shut it down, went upstairs, and started this posting. I wanted to make sure I had everything lined up right in the BCE columns (I know typos hurt) so I went downstairs and started it up. Before checking Q9 and Q10, I checked pins 2&3. They were 5.8vcd and heading north. Vdc for BCE on Q9 was 6.0, 26.5 and 7.2 respectively and 6.4, 26.5 and 6.04 on Q10.
