TO-220 was designed to replace TO-66, TO-3P is meant to replace TO-3.I believe the TO-220 was specifically design to replace the TO-3 and TO-66. I don't recall the reason being stated in the datasheets and ref guides and I've scanned what was published there.
Good call! I forgot to mention itGoing this route. The ring connectors will need to have plastic bushings as well, To insulate the collector lead from the heatsink.
Looks expensive if it has a major failure. I guess the question is; what are you welding? lolView attachment 1319048
2SA1117/2SC2608
TO-3
200V
17A
200W
20mhz
YAMAHA PC5002M
10 pairs per channel
Whatever needs weldingLooks expensive if it has a major failure. I guess the question is; what are you welding? lol
