Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
playback and recording Im getting rolling levels and left channel is dull and not as clean as the right. I cleaned the heads good. Is more cleaning needed belts old? or this thing need major service?
clean the internal rec-pb mode switch and also inspect heads for wear. Sadly, beyond this you're unlikely to get very far without the experience of these machines and a service manual and test equipment.
"Rolling levels" and diminished highs is tape skew and low "inter-capstan tension". Tape skew is the tape moving side to side, exiting the proper tape path.
It's a common defect in the 300/400 series. Make sure the capstan shafts are spotlessly clean. If so, then it's time for major servicing:
-check that the head carriage moves freely (by hand). Dried grease is the problem.
-new belts and new pinch rollers will likely be needed.
-see if the counter belt is driven off the take-up hub or supply hub. If take-up, then a new different belt needs to be installed with it attached to the supply hub. This increases back-tension.
-clean/lube the capstan bearings (if worn out, then the deck is dumpster fodder)
Best for a pro shop to do this work. The transport should be aligned with an M300 gauge for best performance. Aligning the heads and electronics with test tapes will be needed as well.
Marrs Comunications can supply the belts. Terrysrubberrollers.com can put new rubber on the pinch rollers.
Not sure why but the 420A has given me more trouble with tape skew than any other 300/400 series model, even though I've worked on more of the other models. Probably based on too small of a sample, so I try not to hold it against the 420A, but I've seen this same issue on three straight now and had a couple of 440A's a 340A, and some 330's in the same period that had no signs of tape skew even though they all have the same mechanical tendencies more or less.
Just got a 420A today of local CL and it was exhibiting the same issue.
I took off the tape door cover and noticed that if I applied a bit of pressure to the supply reel drive, the skew issue went away. Figured it must be feeding faster than the take-up reel could handle it. The I noticed that if I went quickly from "wind" to "play" the problem went away for a moment. After fiddling with it for a while I realized if I hit stop before I hit play, the problem wasn't evident. I'm assuming there's some drag on the take-up side that remains after jumping from "rewind" or "wind" to "Play" that is mechanically absent with the intermediate stop at "stop". I'm also assuming that's probably a mechanical lever being slow to shift due to dry lubricant. I'll take it apart later but for now I'm enjoying the new toy.
Bought it from the original owner's daughter and she had saved the Operating Instructions manual, Tandberg Inspection Card with seven signatures verifying performance and test results, Operating Supplement for the 440A and the 420A, and the 420A Technical Data and Description brochure. If this is information would prove useful to anyone, let me know and I'll scan it.
My recommendations in post #3 apply to your deck as well. Also, if you apply more back tension (BT) and that fixes the problem, that does not necessarily mean the BT is too low. If you are applying more BT than spec, then that can cause speed defects towards end of tape.
