gslikker
Hi Tom,
as you can see from the schematic the phono input is wired such, that it will accept both 3 pin and 5 pin RCA turntable cables.
If the cable provided is DIY and wired the wrong way, it will not work for one channel.
The offset has no adjustment and it depends on the HFE and matching of the input pair transistors and resistors. It will always be negative by default. These -12mV and -19mV are good values, so nothing to worry about.
