AngelAT
Well-Known Member
Hello fellow AKs,
I got a Tandberg TR 2060 in terrible condition- without housing, some parts missing, etc. As I know how good these receivers are, I am trying my best to save it. I have and old TR 2025 that am using as parts donor for lamps' board, top, bottom and sides, etc.
The power amp of the TR 2060 was missing some components - transistors, resistors, etc. The output transistors were 4 different types and also shorted. So I recapped the power board, replaced the output resistors with new 0.68 Ohm/5w wire wounds, some other resistors, the drivers with MJEs, the dif. pairs and basically all transistors at the board, except Q703 and Q704 because they tested OK (and I do not have modern equivalent to use).
While waiting for the outputs to arrive, I recapped the rest of the unit.
My problem is that I have strange voltages at the rectifier CR775 -> +73 VDC, -7 VDC (with DBT). I also do not get the +40VDC at 12v bulb - I get 35V. Otherwise the 25VDC from the power supply is present. At the filter caps (checked OK) I get -73VDC;-33VDC and 7Vdc;-33VDC. When I check the trafo I get 29.8 VAC at pins 22 and 23 with respect to ground and between pins 26 and 28 I get 63 VAC. These make me think/hope the trafo is OK. Replaced the rectifier CR775 even though it measured ok. Also checked the four caps around it - they are also OK.
Do you have Ideas what might be causing these anomalies?
. Unfortunately I have no frames laying around to help you with.
