Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I don't know if you guys have seen the Tandberg in pearl blue?
I had to fix the sides which had chipped off angles and then repaint.
I will try to find blue LEDs and see how things go.
Still there is a little problem putting it together as all outer parts are from the TR 2025. Screws will not fit perfectly, but I will come with a solution for this.
Also I plan to print the name/model on a silver sticker and this way resolve the lack of proper top frame.
Now thinking that these blue panels will go better for the blue glow receivers like the tr 2025, but maybe when I get the original tr 2060 panels, I will use the blue ones on a more appropriate one
The 2025 and 2060 wood parts should be 100% interchangeable, I've swapped them myself in the past (same for 2030/2040/2045 - all of these had the same cabinet dimensions). It's only the 2055/2075/2075 MkII/2080) that used the larger cabinet parts.
Many of the European production used a matt black finish rather than wood grain, that would probably look better on the 2060 than a colored paint (with or without the pearl finish). Call me conservative, but these don't seem to be designs that benefit from a flashy colored cabinet, that's a better fit to later more modern designs from the '80s I would have said.
