WiDucPioneer
Member
My poor old TR2055 is in need of a replacement relay I think. I believe this is an early series unit. I noticed the other day that the right channel was cutting out after the unit heated up. I at first thought about dirty contacts so I cleaned the speaker selection switch as well as volume and balance but that wasn't the problem. I then had the idea of knocking the relay gently with a screwdriver handle. That indeed was the problem.
I then de-soldered the relay (pin / not spade type) and took it apart to clean the contacts using the contact cleaner soaked index card method (CRC not DeOxit). The contacts looked immaculate but I did it anyway. Well it was worse when I soldered it back in. Neither channel came on. I then got it out again and decided I had bent the contacts further away from the armature even though I cleaned the contacts gently. I bent them a bit closer to the armature contacts, soldered the relay back in an voila, both channels are working. Now the next day the right channel is cutting out again after the unit heats up. I know this unit had a hard, heat-rich previous life gauging by the condition of the internal components.
Then I got into finding a replacement and looking at all the threads on AK. The original relay is a V23154 series which are somewhat available from TE connectivity but most are not stocked by anyone. It has three pins on the front row of the relay (opposite the coil), a middle pin in the second row and two pins at the corners on the back.
I believe it is a DPDT (with two contacts per channel), 24 VDC, 1000 Ohm coil resistance. I can't find anything yet in stock that matches these requirements from TE that is like to have the same pinout arrangement.
Does anyone have any suggestions for a replacement? I may have to continue trying to nudge my current one to keep it working as for Tandbergs it seems like quite an exercise to find the right replacement relay.
Thanks!
Thanks!
