GabeD
Hi all! I have been restoring a set of Tannoy Lynx speakers from the Wildcat line from the mid/late '80s. It actually took me a while to figure out what I had as there are no model names on the cabinets and no part numbers on the drivers. Google image search helped a lot. The drivers are the K series - either K3149 or K3148 - I'm not sure which or what the difference is. (EDIT: It turns out they aren't. See later in the thread, these are 3169G) Can anyone shed more light on what I have?
More about the system here:
http://www.preservationsound.com/wp-content/uploads/2010/12/TannoyWildcats1984Catalog.pdf
Apparently the Lynx was designed to work with a sub called Leopard in PA applications. They appear to share drivers with the Little Gold monitors of the same era. (EDIT: they are actually closer to the DC 4000 speaker of the same era with the 3149 that has fabric surrounds). I have the grilles for the cabinets as well, not pictured.
My dad got these speakers in the mid '90s. As a kid I remember helping him paint them black and refresh the cabinets. They were painted white with a very thick paint when he got them and he wanted them to be black and Tannoy gold. My guess is that they were used in a church. He also added the cups in the back with binding posts in addition to the XLR jacks.
He liked to listen to the Beatles on them as he wanted to hear the music "the way it was heard in the studio" - on Tannoys.
I never really liked them. They sounded very lacking in bass with shrill midrange. They ended up with me recently and I was curious to check them out again after quite a few years.
I pulled the drivers and inspected the wiring that was added for the new the terminals only to discover that the two cabinets were wired out of phase and had been since the mid '90s!
With a little more checking I discovered an open resistor in the woofer section of one of the crossovers. They are Tannoy Type 1047.
I have no idea how long the resistor had been open. Perhaps since he got them. With that discovery I decided to rebuild the crossovers with new components as I don't know the early history of the speakers, what they were subjected to or why they were removed from service. I found suitable Dale 25 watt resistors in the same package as the originals. They were riveted to the heat sink/mounting plate and had to be drilled out. I went with Dayton caps, touched up the solder joints and used deoxit on the pins of the terminals to connect the crossover and drivers.
With the crossovers sorted I checked out the drivers only to find that one of the HF diaphragms was open. Everything else checked out ok. I inspected the open diaphragm and saw that there was a tiny hole in the winding at the very edge. I was able to use a tiny amount of solder to bridge the gap and repair the winding. It measures 9.1 ohms, the same as the good diaphragm. I put a little super glue over the repair. Hopefully it will hold!
I re assembled everything and started listening. They sound incredible! So much different from what I had heard in the past but of course they would be with functional crossovers and tweeters! The sound is very revealing and detailed with a broad stereo image. The bottom end, however, is lacking.
I started researching more information about the lack of bass and the internet suggested that the surrounds could have hardened with age causing the movement of the driver to be restricted. The surrounds are a doped fabric.
There is one person out there that I was able to find - Zen Mod - that has reconditioned the surround of a Tannoy. He has a page which details the procedure to remove the old dope and re apply a new dope. He is working on the 15" version of the drivers but it looks like it should apply to the 12" versions as well. The details are at the bottom third of the page:
https://www.zenmod.in.rs/loudspeake...n-3-previous-episodes-cumulative-with-finish/
While that sounds straight forward, the new dope that he uses is "rat glue". I assume this is what you would find in a mouse/rat glue trap. I'd rather use something purpose made so I began researching surround dope and came across a lot of people repairing KLH and Sansui drivers with various things such as Permatex and PVA. The KLH guys seem to recommend a product from vintage-ar on ebay that is close to what KLH used. Would this be appropriate for the Tannoys?
I wanted to get any thoughts on how best to proceed with freshening up the surrounds. I understand that the bottom end will likely not be earth shaking with these speakers designed to be used with a sub, but any improvement will help. Thanks for your help!
