Tape Decks
This might be a stupid question for you guys but I’m still learning. I have 3 tape decks. 1 reel to reel, and 2 cassette decks. The kenwood receiver I have only has 2 spots for a tape deck. My question is can I use a RCA “splitter” instead of a RCA “switcher box” if I will only have 1 deck turned on at time ?
Thanks Jon
I have found these to be quite useful in connecting multiple decks to a receiver with a limited number of audio inputs and outputs. I know that Sony also used to make a switch box that you could connect several decks to and then select one of them to be connected to a receiver. That unit would also allow you to connect the output of one deck to the input of another for dubbing purposes.
https://www.radioshack.com/products/radioshack-4-way-audio-video-selector-switch
If you had an ADC or other brand of Eq in line it can also give you several extra monitor features/buttons that you could use depending on the model as I have:)
DBX 200X is a good solution. It provides for 3 signal processors (selectable routing from pre or post processing) and 3 tape decks or other player/recorders. You can dub from any of the decks, to any of the other two, and monitor which ever one you wish.
Enjoy,
Rich P
DBX 200X is a good solution. It provides for 3 signal processors (selectable routing from pre or post processing) and 3 tape decks or other player/recorders. You can dub from any of the decks, to any of the other two, and monitor which ever one you wish. I do that! Thank You
Enjoy,
Rich P
