granto
Hello,
If I record to tape with no inputs plugged in, the resulting recording is quiet. But as soon as I plug in the outputs of my PC's audio interface to the inputs on the 414, even with no signal, each respective track of the recording becomes noisy. However, I do not hear this noise in my monitor during recording (monitoring L-R). I can also plug in a mic and record just fine with no added noise.
Seems like a ground loop kind of thing, right? Everything is on the same power circuit. However, it's more of a white noise than a hum. I also don't understand from looking at the signal path why I wouldn't hear it in my monitor and then all the sudden it's on tape at pretty high levels.
Any suggestions to avoid this? What about trying to plug into a different circuit? Would trying that help diagnose things? I'd have to get a super long extension cord to even test this! If it matters, I don't use a power conditioner because I've never run into an issue.
Also, I have a cheapo replacement switched mode power supply for the 414-- would I benefit from using a linear power supply? I found an unregulated linear PS that meets the requirements. My simple understanding is that a linear PS may reject mains hum better than an SMPS.
