question about this
- • brown heater 6.3VAC CT is connected to transformer case and thus Audio GND, bypassing heater CT AC coupling
is the CT connected to the trafo case internally, or do you mean that the lead is external to the transformer, but connected in the wrong place?
and this
- • power tube sockets should use flat head screws or be atop the chassis to preclude KT-88 rocking
I've used a lot of standard pan head screws with bottom mounted octal sockets and not had issues, but the socket top stuck above the chassis further than the screw head. Are the sockets used in this not of that sort, or is it just a thick enough chassis that the socket doesn't poke up far enough to clear the screw heads?
I'll have to check the trafo polarity thing. Its not something I ever considered looking at. When you say less noise, thats less noise as measured at the output of your "sniffer" choke?
surprised the bias noise is that noticeable. Many old amps had half wave supplies but between the low current draw and the fact it goes in common mode, the residual noise was generally a non-issue. What was the original circuit, a single cap input filter? I'd figure even a simple CRC would be enough to make it quiet enough.
I own only one power amp that has a full wave bias supply though, my Pilot SA-260. I have a couple of integrated amps that are full wave, but only because they also used DC tube heaters and the bias supply is tapped from that.
I always like seeing detailed posts like this from experienced people. I find it instructional and gives me ideas on how to improve my own stuff.
