The new Tung sols sound great too! I have a quad of svetlana 6550 c waiting to try I can let you know. They were only $100 a quad so I had to try them.LOL! Ok, Thank You! I was just looking at them and saw Tung-Sol makes some.
most amps I have sound more open than mc30s that don’t have much sparkle up top.
The OPTs are designed for PP/P operation, four tubes per channel.I've used the Sovtek KT88s (my favorite - used to be easy to get) now I use Gold Lions. I also use Sovtek 6550's. I haven't noticed any difference with any that I've tried but those Sovteks have lasted quite a while.
I think when my M125s are finished - I'll likely just run two output tubes per amp in order to extend tube life.
See my above postCool, Thank You. Yes, please let me/us know.
You can run the M125s with two tubes per channel and bias each tube individually vs in pairs. I've had good luck with that setup - and it is for sure easier on the rectifier setting the bias at half the value. In all I think it is an overkill amp running at two tubes. I've had all my issues when running at the limit and with four tubes.The OPTs are designed for PP/P operation, four tubes per channel.
Great to know as I've always wanted to try some KT120's - but man I've got a full stock of KT88s and 6550s.I’ve run 6550, KT88, and KT120. Never noticed much difference, the KT120 marginally edging out the others I’d say. Driver tubes another story.
6550's are one tube I haven't had any experience with. I would like to try them, but two quads will cost a lot.
Some recordings can throw you off making you think something is wrong. I was listening to a new CD sometime back and was hearing some noise and intermittent hum along with some distortion in the midrange. I thought something was wrong with my amplifier or preamp. But it turned out to just be a really dirty recording. If I had been the artist and heard the final mix I wouldn't have been happy.After listening to the super bowl tonight I will say that midrange sounds a bit more hollow / sucked out with the svetlana 6550 after coming from the old stock Tung sol 6550 (three hole grey plates). You never know if that’s from the recording or what.
it's stated on the Tube4hifi site that two tubes can be used per amp instead of four if you wish.
