beatcomber
AK Member
Of those two, the Shure would be my choice.
Nah, it's fine. I used one for years when I had a Technics, and never had tracking error problems. We're not talking about setting up a $50,000 turntable with a $10,000 cartridge, it will work just fine. There's no need to make things more difficult.
Couldn't agree more. When I was a turntable noob AK threads on cartridge setup used to terrify me; folks made it seem like defusing an atom bomb. Then I took a deep breath, used the overhang gauge, and was listening to a new cartridge 10 minutes later.
(That said, I don't touch the Clearaudio myself, that's the dealer's job :yes![]()
I would think the M97xe would sound good on it
He means do not twist the cartridge in the headshell.
K.I.S.S.
Hello!
Sorry if this was posted before. I just got my Technics overhang gauge from the auction site. I will be using it for my Audio Technica ATLP-120 with the stock cartridge. I'm planning on getting a new cart soon so i decided to get one. I have some questions. When i'm trying to align na tip of the styli to the gauge tip the styli is a bit misaligned in the center. Is this normal? I saw this video on Youtube and we have the same problem. https://www.youtube.com/watch?v=6hrnS1Y8Z2M
Should i align the styli to the center? Doing this the cartridge is not centered on the headshell. It's kinda weird.
Last question. Should i align the tip of the styli to the gauge or the tip of cantilever?
Thank you!!!
Just a warning - the overhang for the AT-LP120 USB is 53mm
http://www.audio-technica.com/cms/turntables/583f30b3a8662772/
That means that you should extend 1mm ahead of the edge of the overhang gauge
That said I have read that people use the Technics overhang as is with the AT-LP120
V
How about other carts? I'm planning on getting a new one. Which would be better for ATLP-120? Denon DL-110 or Shure M97xe?
Thanks!
k.i.s.s.
Enjoy the![]()
Apologies for the previous link - I just realized it doesn't take you to the info - here it is, from the Q&A section of the AT LP120 page
The effective length of the tonearm on the AT-LP120-USB Turntable is 230.5mm which puts the stylus overhang (the distance the stylus tip extends beyond the center of the spindle when the tonearm is directly over the spindle) at 16mm. I believe the Technics overhang gauge sets the stylus overhang at the spindle at 15mm. Extend the stylus tip 1mm beyond the end of the gauge and you should be good to go. To verify the overhang is correct, simply measure 16mm out from the center of the spindle on the side of the spindle opposite the tonearm pivot when the tonearm is positioned directly over the spindle. The styus tip should be at the 16mm mark.
V
It depends on the type of character of sound you prefer. If you prefer things on the warmer side of neutral, go with the Shure. If you prefer a brighter, more detailed presentation, go with the Denon.
Thanks V. My overhang for ATLP was short to 52mm before and it sounded fine but then i used this gauge the details are better. I made sure the stylus tip is atleast 52mm or more. I will try to do 53mm next time i tweak the turntable but so far i'm happy with the 52mm overhang. How was yours?
Sent from my iPad using Tapatalk
For me, the result was a great reduction in surface noise... it sounded a like a bit much, the overhang adjustment produced a significant reduction... All this with a Shure M97xe.
I double checked on the AT95e that came with the table, yup, 53mm, straight in the headshell
Thnx
V
Sent from my SM-N900T using Tapatalk
Thanks. Ill try 53mm in. Few days. Hows your shure with atlp120?
Mine is set to zero and still the headshell is a bit lower than the tonearm tail. Is this really critical? Maybe i cant add a rubber matt or something?
