Anaxas
Member
Hi,
On my Technics SA-500 the FM suddenly went 'mostly' out .. but quite faint when the muting is off, and silent when the muting is on. AM never worked for the couple of years that I owned it.
While trying to find the issue I measured the transistors and Q2 ( 2SC1047 ) has an emitter voltage of 1.0 Volts , but in the service manual it should be 11.1 V . The base measures 1.7 and the collector measured 11.7 (11.2 in the manual) . I pulled the 2SC1047 from the board and it still tests as an BJT-NPN transistor (hFE 85) which at rank D is low (there is a D on the chip) , which should be 100 - 260.
I re-capped the tuner board to eliminate the rest of the green crusty legged capacitors (power side was done years ago) and replaced the equally messy VR101 and VR102. As somewhat expected , this did not solve anything, but there were several capacitors way out of spec.
I'm tempted to replace the 2SC1047 since it's reading so low on the emitter, but technically I'm out of my league on analyzing the circuit. Could there be anything else that would cause the voltage there to be so low?
Any help would be appreciated.
