Technics SE-TX100 right/left channel operation indicator bulbs
letsfixit!
I hope I'm in the right section for someone to see my request for specs for the bulbs for right/left channel operation indicator bulbs in Technics SE-TX100 dual mono amp. I have three of these amps and only two of the six bulbs are working. I looked for a service manual on HiFi-engine but no luck. The Technics SE-A50 is basically the same as the SE-TX100 but that service manual does not spec out the bulbs. I know they are 3mmx5mm tall. Need to know voltage and amperage.
Crazy question is can I measure the voltage coming out of the socket for the bulb with my multi-meter to determine the voltage of the lamp? Then I would need the amperage somehow...
Here is a pic of the light and the amp.
Any help would be greatly appreciated!
