Technics SL-1800 ?
Some Great info here I recently came up on a 1800 MK II $35 in great condition everything worked dust cover had some mild scratches RCA had to be replaced. It did however come with a needle and cartridge I'm not familiar with no markings Gold Platted Can anyone Identify this cartridge Thanks for your help
I just purchased a console that had a Technics SL1800 MK2 in it. Cartridge was damaged so any suggestions on a fairly priced cartridge also the dust cover is gone. Anyone know where I can purchase a replacement?
Welcome to the AK turn table forum.
You can look for a new or used dust cover on Ebay.
If you can identify the cartridge, you can just replace the needle/stylus on it. :)
I haven’t had any luck finding a dustcover for the SL 1800 are they interchangeable? Do you know any websites that would get my search started?
The needle appears fine new even but the cartridge itself is damaged its split in two
Post a close-up of the cart.
I do believe the SL-1200 cover will fit as well .... but those are getting rare and $$$.
It’s an Empire 245 E
Cartridge-wise that AT cart I linked to is a good choice, current (new) model and upgradable in the future. The Nagaoka plug-n-spin carts offered by the same vendor are another good choice and also upgradable. Either case I'd suggest you start with one that has elliptical stylus. Your budget will decide.
Highly suggest OP go to Vinyl Engine download owners and service manuals. Manual will show correct headshell, be careful not to end up with junk copy they call "Technics style". Manual version of table is excellent choice no auto functions to mess with.
I have a first-gen SL-1800, and I use an Ortofon SH-4 headshell with a 2M Blue. It's a very effective combination. Will upgrade soon to a bronze, in another SH-4. The stock Technics headshell with the single-screw carrier design doesn't work with the Ort's top threaded screw inserts, or any other makers for that matter. Otherwise, I find little to fault. Great decks. Mk IIs are different, but not enough better that I feel jealous.
I have a late 77 SL-1800 mk1, with a technics EPC 270 cartridge with a Nagaoka G28 -270ED stylus. The deck was fully restored with new pots, switches, board components and solder, and new litz wiring; it will probably outlive me now. The 270 sounds great with the Nagaoka stylus (Nagaoka made the technics carts so no surprise) and there is the option to fit a Jico boron but that's probably overkill. I tried an AT VM95EL and it wasn't as good. Tried a Goldring 2400 (also made by nagaoka) was great but not sufficiently better to justify the extra cost. I think the Nag 110 or even the 150 would be an ideal partner.
Sounds like you've got a nice combo there ... enjoy! I'm just working on getting a SL-1700 Mk2 up and running again that hasn't been used apparently in ages.
Nice table, certainly worth the effort. Even the pre-MkII models do everything a TT is supposed to do well enough so as not to be embarrassed by more modern decks.
Anyone tired an Ortofon Blue on an 1800 (or any of the 70s SL range with same tonearm)? I've tried the AT VM95ML and found it to be a bit boring tbh, but that could be incorrect load matching perhaps. The Ortofon specs are much closer to my phono preamp. Currently using an original 270C-II with the nagaoka G28 stylus, it's rather good.
