12ax7
I'm not sure if I have any WD40 in the house right now. Which one of these from Tower would I use if I were to go with the silicone? Thanks.
There seems to be some confusion between silicone grease and silicone oil. The grease will remain slippery regardless of it's weight (caliper grease, plumbers grease). Silicone oil will get progressively "stickier" the higher its weight number. That's how it slows or "damps" the descent of the cue rod. You don't want any contaminants such as penetrating oil, motor oil, sewing machine oil or grease on the cue rod, clean it well with alcohol before applying silicone oil.
As far as WD40... yes, it will free up and lubricate the cam... for a while. If you've gone to the trouble to get to the bottom of the tonearm, why not take the extra step to remove and clean the cam and then use a proper grease to lubricate it. It will operate more smoothly and last longer. A "sticky" silicone oil is not the proper lubricant for the cam.
OK, time for my third cup of non-decaf.
