Always measure DC voltage in audio equipment with the - (black) probe on ground. Nothing past the rectifier diodes is going to be AC unless you have a seriously compromised ripple filter (the 945 transistor) or a bad capacitor, radio frequency portions of the tuner aside.
You need to locate a service manual, else we are fishing in the dark. You will need to compare the voltages on the schematic with what you actually have to figure out what's wrong.
That said, it's highly likely you have a number of bad electrolytic capacitors, they are well past their expected life. I've found more than one shorted or open, and plenty of them leaking in similar age equipment. Given that you found the D880 transistor to be hot all the time the tuner was plugged in it may have an "always on" circuit and a soft switch to power it up. The always on part of the circuit holds the station memory.
Shorted or low resistance capacitors can indeed pull the voltage down, the ones I mentioned are high on the list. The 6.3V 1000uF cap is probably the station memory cap, and the one I had in a Kenwood tuner of similiar was bad. So were most of the rest of them for that matter.
