tnx for the reply, mains is okPower up the amp then check for mains AC voltage at the switched outlet at the rear.
Unit has separate transformers for L&R channels, tranformers
have thermal fuses. Maybe failed power lamp/LED?
Unplug the unit, remove fuses F1 and F2, check for continuity on transformer
primary between red and brown wires, repeat for second traf. Reinstall fuses.
Check secondary transformer voltages. Measure AC voltages between pins/posts
506 & 507
506 & 505
511 & 512
512 & 510
506 & 507
506 & 505
511 & 512
512 & 510
506 & 507
506 & 505
511 & 512
512 & 510
Highly unlikely that both power transformers are bad. Are you sure its not just the lamps that are burned out? Have you connected any speakers to it?
