Ivan T
I have the Technics SU 8080 integrated amp with a channel imbalance problem - left channel is quieter than right channel even if I run it in power amp mode. All electrolytics (except power supply ones) have been replaced with Panasonic FCs, FRs, Elna Silmic IIs and some Nichikons, depending on availability. One of power supply caps (C503 - left channel) drains much faster than the other ones when the amp is off. Any suggestions from the local community? Is this a common issue with this amp? Where should I look? Speaker relay, volume and/or balance pots, speaker selector (sounds a little "scratchy"), direct/via tone switch ( sounds a little "scratchy"), DC/low cut switch (sounds a little "scratchy"), power limiter boards, resistors? Please, help.
P.S. When I try to adjust power limiters according to the service manual - nothing happens to the waveform on the scope screen.
