Flapper
Member
Hi all,
A few years back I bought a second hand Technics SU V8 amp which quickly became my favoured amp (slightly, over a Sansui AU-317 that I also like).
Every so often I have set the DC balance, Clamp Voltage and ICQ without problem using a multimeter and the instructions in the service manual (pasted below.)
Recently the right channel developed some distortion so I went to check all the levels and I noticed that perhaps one of the trim pots has stopped working or at least has stopped having any effect on the ICQ level of the right channel.
DC balance is still settable to 30mV using VR301 / VR302 (see below).
Left channel Clamp voltage can be set to 1mV using VR603 and ICQ then set to 40mV using VR601
Right channel Clamp voltage can be set to 1mV using VR604 (when zeroed) but then when I move VR602 to set the ICQ it won't move off 1mV. It's like VR602 has no effect any more and the sound is gritty.
I can 'remedy' this and move the ICQ reading up to around 28 mV by messing with the right channel's DC balance (VR302). This temporarily removes the grittiness, but the sound is not hi-fi and - obviously - the DC is not meant to be pushed in this way as I guess it will be pushing all sorts of other things out.
I have ordered some new 1kOHM trim pots and will replace VR602 to see if the pot has gone bad. Does this sound like it will be the culprit or does anyone have any other ideas why I'm suddenly unable to set ICQ on the right channel?
Thanks for any help.
Sam
Sam
