Ah shoot. Good idea, sorry it didn't work.I swapped diodes D307 and D308 - little round baubles. I've packed the amp up as the missus will be back soon! I'll dig it back out again tomorrow. Really appreciate the help.
Voltage between base of Q614 & Q616 should be 4V
what is voltage like on Emitter on Q316
With amp off, check for Collector-Emitter shorts on Q606 and Q610
MA26-I is like a stabistor diode
The request was for voltage between Q614B and Q616BI'm not sure how to measure this. I put the black probe at Q614B and put the red probe at Q616E and it read -576mV
Better to use the diode test function on your MM, see diode symbol.I've set the multimeter to OHMs and tried to read between B & E
Maybe give it another day, people in different time zones need their sleep...I'll hang on for a bit and then call the tech later
Your -576mV suggests something not ok.
Measure Q614B to chassis/GND. Repeat for Q616B to GND
Blimey. Just opened up the mains plug (which I guess I haven't done since buying the amp a few years ago) and there's no earth connection! Surely that's super dangerous and time for it to go to the techie? Live and Neutral are both wired correctly.
Emitter of Q316 and ground is -65V
R348 shows nothing on diode setting. It shows 47.5 on the 200k OHMS setting.
Reluctant to turn it back on now with no earthing.
Coming from the UK you may be OK, but there are lots of counterfeit electronic parts on Ebay.Found some direct replacements on ebay. I'm going to buy two in case the other goes bad:
https://www.ebay.co.uk/itm/2SC2632-...567398?hash=item4b12990ce6:g:kBgAAOxy-W9SPKny
