Thanks ! I have Modi3 and i love it. I like the idea of the ageir and the freya, so that i expand later, but I probably won’t need to. The other items that have caught my eye are the parasound new classic series amp integrated or separates and the rogue sphinx. Those options will be more money though.I would recommend trying out the Schiit Audio Aegir - 20w / channel into 8 ohms, and 40w into 4 ohms, Class A like $800. It has been called THE best thing that they make. If you need a preamp, then consider their Saga + or Freya S or +.
I am also wondering if anyone here has experience with the XTZ edge amp. Its class D and 150wpc in 8 ohms. It gets really great reviews.Thanks ! I have Modi3 and i love it. I like the idea of the ageir and the freya, so that i expand later, but I probably won’t need to. The other items that have caught my eye are the parasound new classic series amp integrated or separates and the rogue sphinx. Those options will be more money though.
I have not had great experience with Class D amps. And I somehow think a really sensitive speaker has no need for that much power. Class D amps have low pass filters to truncate the power supply noise. I am guessing that a simple, clean amp design - quality above quantity - is what speakers like the Lore are designed for.
Thanks! Everyone for the knowledge!!!’Thats my experience also. Tektons tend to be pretty revealing - it pays to be particular about upstream equipment.
That said, I have not heard the Shiit products or a class D amp so I can't comment on one vs the other.
audiomaniac, I really like my Enxo 2.7Thanks. Pretty heavy for me at 70 lbs. The 2-10 Perfect SET would probably be great but those are 76 lbs. Ugh! After looking at stand options for the IM and cost, now I'm moving toward other choices. Maybe an Enzo 2.7 or even a Lore of some flavor. I need to call Eric.
Hey DeFriend, you just got those didn't you? I might be mixing up my forums. Anyway, I wonder if I could drive the Enzo 2.7 with 40 watts of tube power.
Id love to know how you like your ultravalve. Do you use them with Tekton speakers today? I am interested in either the ultravalve or the set 120 and tube preamp from AVA. The reviews of both are equally positive. I have Lores and am interested to know if either of these would be good option. Thanks!!DeFriend, thanks for the info. I'm using a AVA Ultravalve EL34 tube amp that makes about 35-40 WPC.It's a sweet sounding amp that is a little brute! I believe the 2.7s are 6 ohm nominal and 4 ohm minimum so it might work OK. I guess Eric is always a little optimistic about the sensitivity rating of his speakers but so are most manufacturers from what I've seen.
Thanks! I will check out the audiocircleHi Chalkdust- I love the Ultrvalve. It is a little brute of an amp. I don't have Tektons yet but I would think they might be a good match. I'm currently driving some Ascend Acoustics Sierra 2 monitors that are only about 85-86 db efficient in a small basement system. But Frank likes Salk speakers and they aren't much more efficient. I'm looking for something that would be easier to drive, full range and tube friendly. Tough to find for a little 35 watt amp! Frank makes good stuff! If I went SS I would look at one of his amps. You should check out his forum on Audiocircle.
Call them up and ask. Talk to Eric, the owner/founder/designer. From what I hear he's super friendly and very willing to help you figure out the best model and options for your system and your budget.I’m in the planning stage of getting my next set of speakers. Think I have it narrowed down to the Lore but there are now three different tweeter options and I’m confused. The Lores can either the regular or the Beryllium upgrade. Then there is the Uruz which looks like it is the Lore but with a ribbon tweeter. It’s also less expensive than the beryllium upgraded Lores. Anyone have any idea what the differences are between them? I anticipate using the speakers with low powered tube amps, does the ribbon tweeter present any problems for those?
Also might be interested in a fancier color but I don’t see a place to see what is available. Is there a place to see examples of the different paints available?
Thanks for any info!
