sonduciel
Member
In the beginning, I was tempted to do some "equalizing" with my Electrons. Actually, Eric, at my request, sent me a pair of resistors to attach to the tweeter array to calm down the upper mid-range. I'm so glad I never installed them. These are speakers that will respond to everything else in the system. By gradual evolution, involving burn-in, tube-rolling, upgrading cables, and speaker placement, I got them to the point that they sound fabulous most of the time. And when they don't, a quick headphone check directly out of the DAC usually demonstrates the problem is in the recording, as you have noted in your review above. If I were you, I would spend a little more time system tweaking and tuning, before spending a lot of money on a physical equalizer solution.
I made an interesting discovery with toe-in. I do mostly near field listening, about 8 feet from the speakers. In my room at least, I found the best balance was with the Electrons practically parallel to the rear wall (very little toe-in). With the tweeter array firing right at me, the sound was not as balanced.
I should also mention the low-end. The Electrons are by no means shabby in that area, and once I figured out some problems with room acoustics, they sounded even better. Nevertheless, when I hooked up my REL subwoofer to cut in around 35-40 hz, the bass dynamics were really stunning and the whole low-end tightened up. It takes a bit of twiddling to get the volume balance right, and the crossover point right, but when you do it's magic. The REL pairs well with the Tektons. Something else to possibly spend your money on in the future....
