Alright...so I've spent about an hour with the DI's and my initial impression is that these are pretty impressive. The most noteworthy characteristic so far is the sound stage dimensionality and image resolution. This is some of the best I've heard in my system from box speakers and up there with some of the best I've heard, period (I've owned Maggies, Acoustats, and a few different open baffle designs). In a room that has virtually zero acoustic interference and adequate space for speakers this size, they indeed have enormous potential for the "players in the room/holographic" experience and, if you can get them set up properly, will deliver the experience rather handsomely.
I currently have the DI's positioned about six feet from the front wall and five feet from the side walls with nine feet between speakers and the listening spot twelve feet away from speakers. Toe in has the axis firing at the outer edge of my shoulder (which is what I think Tekton recommends). With this scenario, the inner detail in the reproduction of sonic images is just fantastic. Images aren't just clear, but have a sort of solidity and texture to them that truly breathes life into the image. This is one characteristic that I feel delineates exceptional hifi from great hifi. Just about any set of better than decent speakers I put in this room will generate well defined sonic images. But the really good stuff takes that a step or two beyond, as if the images are being infused with some sort of concoction that brings them to life...like a cartoon compared to a comic. The depth, height and width of the sound stage is vast but not exaggerated. Movement of sonic images in the sound stage is on a continuum rather than jumping from one location in space to the next ("Where There is Smoke" by Dominique Fils Aime demonstrates this pretty well). D'apolitto arrays, with their point source acoustic center, excel at image and sound stage reproduction. This "poly cell array" between the two mid-bass drivers may just be enhancing what is already a good thing. Regardless, something is working here...and working very well.
Vocals have great texture and tonal accuracy...as do just about all instruments. Horns and brass have excellent presence, but are perhaps just a little too polite to be considered realistic. Same with percussion and drums. Compared to speakers I have with large, horn loaded compression drivers (Klipsch Epic CF-4, Altec 19), the DI's just don't have the same degree of "snap" to the leading edge. There is respectable tactile presence, but big horn loaded compression drivers are simply exceptional at the reproduction of percussion instruments and the DI's aren't quite there.
Low end performance is very good with plenty of chest thump and authoritative weight without bloat (they were a tad boomy in the mid bass before I put isolation pads under them)...but switching on my JBL 4648 subs brought even more of that into the fold. With some tracks it's a little too much with subs...with others the subs really make presentation a very compelling experience. Probably very subjective territory here, so suffice it to say they can produce very satisfying bass on their own.
From a macro perspective, the DI's provide a very engaging, fulfilling listening experience. It's the type of speaker you can nit pick if you want, but ultimately you realize it's kinda pointless because any shortcomings are far overshadowed by all the things they do so remarkably well. I look forward to trying some different gear combinations with them. Currently they're being driven by a White Oak Phase Linear 700B (around 475wpc@8...not sure what the power rating is at 4 ohm which is what these DI's are), a highly modified Adcom GFP-750 pre, a Denafrips Pontus II and WiiM Pro streamer round out the source components. Speaker cables are AudioQuest Hyperlitz Midnights and interconnects are AudioQuest Ruby.
Worth noting is that I acquired Aerial Acoustics 10t mkii's about a month ago. I haven't had much time to spend with the Aerials, but I've spent enough time with them to determine that they are my favorite all around speaker. The DI's might just snatch that distinction away from them. We'll see....
