Tekton Owners Thread
I did the same. Recently bought some Perfect Set 12's that were ready-to-ship at a good discount. They sound really good with all my tube gear as well as my Pioneer SX-950.
Don't know if the A stk speakers were built to spec & never sold or fm cancelled orders. Either way, that was the only way I could make the $$ work.
Quite a few tube guys are very happy w the Perfect Sets. Good you could snag them at discount - right place, right time :)
As a bonus, they were white which matches my Lores that I ordered in white.
Encores - initial set up & a call to Eric
I wasn't going to set these up until I finished the listening room - but I am weak & couldn't wait.
Unboxed & mounted the Encores to dollies so they can be easily moved. I did it all myself but its really a 2 man job.
@145#, the beasts are heavy. I'm not taking them off the dollies anytime soon. My back doesn't hurt too bad.
A couple things concerned me so I called Eric & I'll share what I learned.
*Firstly, the website & the reviews I saw show the ScanSpeak mid bass drivers are front ported.
Mine are not ported at all. Apparently about 5 years ago there was a running change. The mid bass drivers have not been ported for some years now.
We had a short discussion about running updates & tweaks.... continuous improvement.
*Also, it looks like there are 8 binding posts at the rear of the speaker. Mine are set up for bi amp & so 4 of the posts are for that.
The upper 4 posts are not binding posts at all. One is connected to the + of the tweeter & one to the -. The other 2 are the same except they connect to the arrays.
The idea is that if you feel the speakers are too hot, too bright, you can install a resistor in the circuit (using those posts) to tame things a bit.
I never saw this explained elsewhere - not explained in a way I understood anyway.
I only streamed a few selections but initial thoughts are the Encores sound very clean. Each instrument comes across distinctly.
I had to have the volume up past 90 db to get the bass to really fill out. This may change w some break in.
I'll tell you that set up in a room, these don't seem as massive as they do in some of the pics I've seen. Not that they're small, but.............
FWIW, I Have these w the tweeter 3' from the rear wall & 3' from the side wall; about 11' between speaker centers.
Encores are toed in slightly, listening position about 11' back from the speakers.
Obviously, there will be lots of experimentation w positioning once the room is complete.
Hope some of this info helps someone. I'll update when I have something constructive to add.
20241002_142938[1].jpg20241002_161439[1].jpg20241002_183435[1].jpg20241002_183351[1].jpg
View attachment 3310613View attachment 3310614View attachment 3310615View attachment 3310617
Wow, those are impressive looking speakers, Bob! Looking forward to hearing all about them once you finish your setup.
Just for grins, 3 generations of Tektons. Lore S, Impact Towers & Encores.
Some serious good music makers here......
Nice! Truly an inspiration and testament to your fondness for Tekton! Are the two smaller pair still in use?
How is the basement coming along?
What is the sensitivity spec for the big ones? What will you drive them with?
I've always been a big fan of getting a good bang for my buck. The smaller pairs will have to go to subsidize the cost of the Encores. I have no space for a speaker collection anyway.
Sensitivity is supposed to be 96db. The issue w these is they are 4 ohms & dip down to 2 at certain frequencies. I think the Onkyo Integra amp should be able to handle them. Had them on for 4 or 5 hours yesterday at a healthy volume & the amp was barely warm.
Basement project is coming along. Put some paint on the LP rack this morning - I'll assemble it later today. Then I build the bass traps.
Victory is near!!
I think Eric puts on a blindfold and throws a dart at a chart with numbers on it.
The Perfect SET's that I have are rated at 96dBs and I have 90 - 92 dB speakers that are just as loud or louder.
A little exaggeration in sensitivity ratings is quite common in the industry. John Devore of Devore Fidelity has said that was one frustration that motivated him into speaker design.
Some Klipsch products are also mentioned as too high ratings on AK.
It's good marketing.
@Bob in WI, looking good. I remember when you got your Lore S. Then, later the impacts. Now so many years later you’ve gone big, really big!
Thanks. The Encores are not as physically imposing as they often appear in photos but not tiny regardless.
Ulfs at nearly 6 1/2' tall must dominate any but the largest spaces.
I was asking about various Tekton models in the Tekton FB group for my small room (10'x12'). One person said that any of the speakers with the ring array require a distance of around 9 feet or more for the array to blend properly (I'll be about 6-7 feet). That's the first I've heard of that, though it does make sense that there would be a minimum distance. Can anyone else confirm this or was he full of it?
IME/O if you are on axis with the center tweeter it should be okay.
If you are into soundstage depth that's another matter with the array.
I have a pair of Impact monitors and sat about the same distance as you. Didn’t notice any coherency issues. That array is smaller in diameter than the array on Tektons floor stander though.
