Tekton Owners Thread
Hi!
New to this forum section. I've been with Audiokarma for close to two years, but visit infrequently. That is, until now, as I just ordered a pair of Tekton Lore 2.0 with ClarityCaps and these are supposed to arrive here by the end of this month.
Therefore, I need some guidelines regarding break-in, positioning, impressions on these babies' sound quality/features (I currently own Decware DM945 Monitors).
I went with these because of the reviews and the high sensitivity ratings. I own a Decware Mini Torii, 4 Watts/Ch integrated amp and really wanted to try a pair of speakers that would allow this amp to really breath and have headroom. My current speakers are the equivalent of 91 dB @ 8 Ohms (94 dB @ 4 Ohms), and sound quite nice. The problem is, these are only small monitors, lacking the cabinet volume for effective "slam," especially when coupled to a small tube amp.
I have read your impressions here so far, but would like for new owners of the Lore 2.0 (there must be just a few of us as these have been released recently) to forward their candid opinion and maybe to kindly suggest any tips or observations which may make my new acquisition blend as fast and as best as it is possible.
Thanks for any assistance.
Edit: Forgot to add I listen nearfield, in a smallish room moderately treated with rigid polyfoam panels distributed around the room's critical locations, with good success. My sweet spot is at 4.3 feet from the speakers' plane, at an equilateral triangle and following Cardas's suggested speaker location in a symmetrical room.
I mite be the newest owner of Lore 2s, less than a month.
Rite out of the box mine sounded great and are still doing same.
How much extra did the caps run you? I didnt know you could do that.
They say here on AK that flat against a wall is best placement for best bass oouput. Not tried it yet. gotta move bunch of stuff around first.
I have klipsch forte's to compare mine to and the lores sound every bit as good.
All I can say is your going to like em.
What a great thread! Just read the whole thing, and it was really entertaining. Eric is making a lot of people happy.
I owned two pair of very early Tektons back when they were all full rangers. I had a ported 6" Fostex in black, and then a 4.5" in wood veneer. Both were remarkable for the low price, and the build quality was top notch, especially the finish. I was moving, and decided I needed to thin the herd. I sold both pair. What a mistake! Especially the 4.5. On any basis it was one of the best sounding speakers.
I guess he doesn't make full rangers any more. But, I am sure his new stuff sounds great. Where does he generally crossover to his tweeters? Is he using them for augmentation, or using them more like a classic 2-way, and crossing over at 1200hz?
I keep going back to the Pendragon web page, but having a hard time forking over the dough without being able to hear them. I see they have a 30 day return policy after shipping and 15% restocking fee.
Have a fairly new MC275, anyone else have this combo care to give their impressions?
They say here on AK that flat against a wallis best placement for bets bass oouput. Not tried it yet. gotta move bunch of stuff around first.
Thanks for the inputs, ferninando. The Clarity Caps were a suggestion from Eric, at USD 100.00. My DM945's have Mundorf Supreme caps, but Eric said those would be too expensive and that Clarity was good bang for the bug.
If it is true you can get those speakers close to the walls, that will solve a space issue in my listening room. Right now, I need to listen at just over 4 feet from the speakers to allow enough distance from the lateral walls to accommodate for my existing monitors' needs. This does not help much with soundstage.
Could you indicate if you have noticed tangible sound quality differences going through the break-in period? Even if the speakers sounded good out of the box, can you tell if these are literally improving over time?
Do you prefer toeing in or out, or do you leave them facing straight?
Thanks for your assistance.
I noticed some not so subtle changes during break in (sound improved) however they could be explained by other variables in my system. One of the common themes that I found when researching the Tektons was that they did require a substantial break in period to achieve full performance. All I can say is that if you are happy with their sound out of the box, they will likely sound even better after 50-100+ hours.
To answer your question, I think they sound better when decoupled from the floor using either the supplied spikes or some of the alternatives mentioned in this thread. For me, slightly toeing them in improves the imaging and coherence. Mine are roughly a foot or so off the back wall, the bass disappears in my room if they are further out. Someone suggested moving them towards the back wall 3 inches at a time to dial in the low end. Hope that helps
I havent yet detected any significane sound changes since new. Im sure that will come. not yet 20 hrs on them.
I like em toed in or about strait. Not up against wall yet. thatll come later.
When there is low end in the source they play it back quite well so far.
It sure does, thank you. I hope I like them out of the box, so I can expect tangible improvements over the break-in horizon.
I cannot place them too close to the front wall, but I need to have them close to the side walls if I want to improve soundstage and imaging, I presume. I'm wondering what the effect would be in this case, where the speakers are not into the room but about 6 " from either side wall and at about 2 feet from the front wall.
I guess only trial-and-error will answer that.
Edit: I forgot I ordered the Clarity Caps (upgrade), which are relatively large ones, according to Eric, so my break-in may take even longer.
That really seems to be the case, as 20 hrs is still too short for breaking-in, I guess. I plan to play placing the speakers around and see what sounds the best ... Thanks!
Thoughts On My New Tekton Pendragons
After 20 + years of having various models of Magneplanars in my music system, time finally came to peek over the top of the panel and see what other options might be worthy of consideration. I was able to hear the Pendragons in a friend's system and that experience, plus reading numerous positive reviews on the internet, made me decide to give them a try.
I have been listening to the Tekton Pendragons for nearly 60 days and have just over 140 hours on them at this point. They sounded good right out of the box, but their character has noticeably evolved as they have gotten more hours under their belt. The Pendragons are impressive in their dynamics, bass response and their ability to handle pretty much any type of music with aplomb. Other reviews have commented that they are not the most detailed of speakers, but to my ears they do not lack in delivering plenty of resolution. No, they do not equal the detail of the Magnepan 3.6s that have been in my system for the past several years, but neither do most other speakers I have heard.
Their sound started to evolve around the 30 hour mark and continued to improve up to 80 hours or so. The last 60 plus hours I cannot really say I can hear any more change, just the continuation of a very satisfying and involving musical presentation. They throw a large soundstage with very good depth, and the authority with which they reproduce a well balanced rendering of a variety of types of music is impressive. As they have accumulated hours, the sound has become fuller with more smoothness. The slight hint of harshness/shrillness that was heard on some recordings early on has gone completely.
The Pendragons sensitivity is 98 dB/W/m, exponentially higher than the Maggies. With the high efficiency of the Pendragons, my Bryston 4B-ST with 250wpc @ 8 ohms gives them all the headroom you could ask for.
Just for grins, the past 10 hours of listening has been with an Emotiva XPA-2 substituted for the Bryston. This amp is providing 300 wpc @ 8 ohms and the Pendragons are responding well. Actually I cannot say much is missing from the speaker’s performance by using this much less expensive amp.
At some point I want to try some tube amplification and see what the glowing valves can add to the listening experience. I would welcome comments from anyone using tube amplification with Pendragons.
I have used several models of Magnepans over the past 25 years, and have really enjoyed all of them. Maybe one day I will cycle back around to planars, but for now the Pendragons are an extremely enjoyable vehicle for transporting me to audio nirvana.
System:
Tekton Pendragon speakers
Arcam CD33 CD player
Vinyl Nirvana /Thorens 150 turntable
Bryston 4B ST/ Emotiva XPA-2 amps
Bryston BP25 P preamp
Cardas Neutral Reference speaker cables
Cardas Neutral Reference interconnects (balanced and RCA)
Pangea power cords
Audio Art interconnects
Audio Art power cords
Powervar Conditioner
Wareeagle,
Thanks for your thoughts. BTW, that CD was my favorite between 1964-66, when I was growing up. At the time on vynil, of course. To this day, I still keep this recording in my select music list, in WAV (24-96) digital files.
I hope your experience with Pendragons is similar to what I'll get from my Lore 2.0 due to arrive at the end of this month (can't wait!). It seems a ballpark of 50-80 hrs would do the trick for steady-state sound with these 10" Eminence drivers ... except maybe for the Clarity Caps, which may extend this period a little further.
Poltrygeist,
Should I do same with my 98db Lore 2s?
Can you give me a direction to look for one?
thanks.
If you can DIY the 2a3 Bottlehead Stereomour kit is hard to beat at it's price point. You can also find owner built/used examples on A'gon and the bay for less than the price of a kit.
A common statement you'll see on audio forums is "there's no such thing as a bad sounding 2a3".
There are also some excellent Chinese 2a3 SET's for under a grand. I really like the Dared and would love to own a Raphaelite Sinovt.
My amp is a Decware Mini Torii SEP, integrated dual mono, at 4 Watts/Ch. It sounds great. The reason I went for the Lore's is because of the high sensitivity ratings and the 8 Ohm average impedance. These specs will benefit my amp thoroughly.
System:
Pangea power cords
Thanks for the review. I'm dying to hear some Pendragons. Can you please post some pictures? I'm sure we would all love to see some Pendragons in the wild.
cubdog
SET amps do seem to be more popular these days. Personally I've never had the opportunity to hear them first hand, in the correct system they are supposed to be pretty amazing.
You can always try swapping in a tube powered preamp into your existing system to experience what they may or may not do for you. Some believe its a way to balance the magic of tubes with the low end control of solid state. Always comes down to correct matching, synergy, and personal preferences.
