Tekton Owners Thread
Set the Lore S's up on bolts with the drivers tilted up towards the listener. I put felt pads under the heads of the bolts so they don't scratch the floor. Mids & highs are more clear, words easier to understand but I think I lost some bottom end. I previously had the speakers sitting right on the floor. The Lore S being the mid tower design is a bit weaker bottom end than some of the other models to start with. Not sure where I'm going with this ... I really don't want to start horsing around with subs.
How far from the back wall? Like I mention earlier in this thread, I found the amount of low end my Lores produced could be tuned by moving them closer or further from the room boundaries.
- Woody
Sent from my iPad using Tapatalk
I did move them closer to the back wall after that discussion & it made a nice difference. They are still within a few inches of the back wall. Some of what I observe could just be a function of room acoustics. The stereo is in our living room so I can't go all out tuning the room.
I havent moved my lore 2s around yet but the distance Iv read about here is like 10" or less as needed. When I get all other thisng relocated I can then position my lores. And get rid of that schlocky table with my Fisher on it.
They are still sounding fantastic.
I tried Poultrygeist's method of using lag bolts in the front to provide the tilt. It is a good idea and improved the sound, but not as much as when I added the Heil tweeters. Now that was a HUGE transformation.
On another note, I have tried a lot of different types of amplification with the Tektons and I keep going back to the hot rodded Bottlehead Stereomour with the JJ 2A3-40's as the best overall sound. Not the loudest or with the most headroom, but man it is HARD to beat a 2A3 directly heated single ended triode (SET) for the highest in sound quality!!!!
As I recall you had/have an N3 APPJ/Miniwatt. Did you try it with the Tektons?
Hi MWalt,
I'm interested in a more detailed comparison between the Hornshoppe Horns and the M-Lores specifically. I have the Horns upstairs (without the Heil) and have owned the regular Lores and currently own the Lore-S. When I bought the Lore-S I was contemplating the M-Lores and I haven't been able to shake my curiousity. I'm mostly interested to know if the M-Lore does anything better than the Horns.
Thanks!
Tekton Lore 2.0 impressions
It's time to offer preliminary impressions on my new Tekton Lore 2.0's, with Clarity Caps.
I have also made some additional room treatment tweaks and placed my SUB between the two speakers, right next to the right one. Speakers are sitting on spikes over a rug.
With only 31 hrs of break-in and 169 hrs away from absolute steady-state (according to the designer), I can proudly say my system sounds better than ever.
Now I enjoy more body and slam, and at the same time equal or even better detailing, without any fatigue. The best sound comes with my Brimar 12AT7's replacing the RCA 12AU7 black plates, as the former used to be somewhat overly beamy with the DM945's, while the 12AU7's now sound fine but tend to be darker in sound and miss some of the details the Brimar's mine out.
One of the features I enjoy more now is the fact that my dial is only at 9:30 for most of my selections (whereas before the most used range was between 12:00 and 1:00. With classical music the level of reserve is evident in the dynamic passages and there is a more coherent flow of the sound overall.
Still early, but I expect further improvements by the end of the year, which is when I believe the new speakers will attain the 200 hour mark.
The DM945's are slightly more transparent in the high registers, but with a recessed mid-range and a somewhat less defined bass, as it had to be reinforced with my SUB as high as 75 Hz and usually 65 Hz. Now, my SUB is just getting in at 50 Hz, with a nice, deep and tighter sound.
I believe all the details are there with the new speakers, just in a more coherent, flatter distribution, without high-mids bumps or piercing highs in some bad recordings. The SPL I find myself listening to these days is lower than before, probably due to the more coherent frequency distribution.
All the above impressions are from listening during non-peak AC power demand hours, which in my place recently tend to affect voltage and reduce the quality and SPL of the presentation from voltage drops.
I feel my Mini Torii is working in a more relaxed environment and offering its best this way, thanks to the higher nominal impedance and speaker sensitivity.
Coherence and slam with all the details is exactly what I was looking for and I'm finally getting. I think the DM945's are terrific speakers in their own right, which need more power or be used as bookshelf speakers or coupled to the Monolith cabinets to be at their best.
Fireblade... interesting observations.
"SPL I find myself listening to these days is lower than before" - same here. & at the lower volume there are not as many room reflections. I wonder if that is partially why the sound seems more clear & detailed.
"without ... piercing highs in some bad recordings" - noticed that too. I have one recording that has noticable sibilance but thats pre WWII & I think its the recording.
Seems there are similarites between the Lore 2.0 & the Lore S which is, I suppose, to be expected. Curiosity requires that I ask which sub you are using.
Hi MWalt,
Thanks!
I can't say that the Hornshoppe Horns (without Heil's) are better than the M-Lore's. They are different. The Horns have better detail, tone and timber; very euphonic, while the M-Lore's are punchier with a bigger sound and better bass. The M-Lore's remind me more of some of the vintage speakers that I like. The downside is that the M-Lore's have a soundstage that seems to be at knee level, hence the posts on tilting them up. Both are very similar in efficiency. It really comes down to personal preference and the type of gear that is upstream that you use. If you add the Heil's to either of them (I have), they become a better speaker. Much better. The M-Lore's no longer need a tilt and become much more detailed. They also improve greatly in midrange and treble. I used Ed Schilling's crossover on both. His cross is run in "series" and result is around 12 ohms of impedance. At that stage, the speaker is easier to drive and seems to mate up with SET better because of of it. Of course, the Heil's run $700 to $800 in cost and I have never had the privilege of hearing the Lore-S. I feel that both speakers benefit from distributed bass, but I feel that about most speakers that the non 1% are limited to.
Let me ask a question to you: Tell me your opinion of the Horns vs. the Lore-S.
Mark
I don't have a proper "audiophile" SUB, just the regular home theater one, although I must say it is very good: Velodyne DLS-3500R.
Specs from the manual:
Product Features and Controls
• DSP-controlled
• 4 selectable presets for customized listening mode
• Night-mode setting
• Mute control
• Built-in 160 watt (RMS) power amplifier (DLS-3500R)
• Adjustable (40 to 120 Hz) low-pass crossover with Subwoofer
Direct setting
• Speaker-level inputs and outputs
• 85 Hz high-pass crossover
• Line-level inputs
• Signal sensing auto turn on/off with bypass option
• Variable volume control
• Selectable phase control (0, 90, 180, or 270 degrees)
• Dual staggered low-pass crossover; 12 dB/octave initial,
24 dB/octave ultimate
8" forward-firing woofer
My listening room is a dedicated one and is small, so this size SUB is ideal for me. In the future I may seek a more sophisticated one but so far it is not a priority, also because it only acts at around 50 Hz-40Hz, with the Lore's providing the rest.
Lore-S v. Horns:
Let me say that I have the speakers in two different systems in the house. I have moved the Horns downstairs where the Lore-S are, but that room is less than optimal for the Horns.
Generally speaking though, the Lore-S are more neutral and revealing, while the Horns have a greater toe-tapping factor. I prefer the Lore-S for 2 channel movies, but for music I think I would like just a shade more warmth in the mids.
I will try the Lore-S upstairs with my Mapleshade Scott 222 at some point as this is my favourite amp with the Horns. I have used both speakers with my SEP EL84 amp from Finale Audio here in Canada which is incredibly detailed (but musical!) and this allows me to see into the recording more than the Mapleshade.
I guess I'm wondering if the M-Lores are a touch warmer and fuller in the mids than the Lore-S.
Lore-S v. Horns:
Damn, I bet that Mapleshade Scott 222 with the Hornshoppe Horns sounds great. FWIW, when I spoke with Eric from Tekton regarding the differences in his speakers (M-Lore, Lore S, Lore, etc.) he said the differences are subtle. If you have the coin, I strongly recommend the Heil's. They are a game changer. On another note, do you use a sub?
If the large Lore S is more revealing than the 4.5" Fostex I'd be shocked.
Loved the Zu's for other reasons as they lacked the detail of smaller FR drivers.
"more revealing than the 4.5" Fostex I'd be shocked " so you figure the fostex driver is more revealing than the SEAS? Lore S is full range 8" SEAS driver with tweeter for help up top.
Revealing is a double-edged sword. What I mean by more revealing is a leaner, more detailed sound as opposed to a richer, more natural sound. I usually don't mean the former as a compliment when talking about speakers. Perhaps I should have just said leaner. That's is what I meant by toe-tapping earlier. For me singing along is a strong measure of how well a speaker (or system) works. Are you bopping along or are you listening attentively to sound artifacts? I've heard and even owned systems that do the latter and know that equipment that dissects is not for me. I'm not fond of systems that reveal everything but let you enjoy nothing. This is what brought me to tubes and to single driver (or at least simply configured) speakers and why I like the Horns. They step out of the way and let you enjoy the music.
As far as revealing goes, I think it is more how a driver is implemented (how the speaker is voiced) than the size of the driver. I own two 4" Fostex speakers: the Horns and the Omega Super 3Rs. The drivers are different (126 v. 127) but the Horns are full and natural and the Omegas are fast and lean. The Omegas are really good for TV and movie dialogue, but for a variety of music they are just too lean. The Horns are less adept when used in a two channel home theatre role, but are more natural and have more body with all types of music. The Lore-S are fast and articulate enough to work for movies and better than the Horns in this regard, but I'm finding them a little lean with music.
And I should add that I've cycled through a number of amps with the Lore-S: a beautifully refurbished Dynamo ST-70, a Glow Amp1, and my Finale F-138 FFX (a killer 5 wpc EL84 SEP). The only thing I haven't done is hoist them upstairs to the living room and hook them up to my Scott. That will be the next step.
But I have this lingering notion that for my ears and preferences, the M-Lores might have had that touch of midrange warmth (and sacrifice some of the detail) that would have worked for me.
And MWalt, I use the same sub in both systems: a TBI Magellan VI with their designated amp. It is fast enough to keep up with every speaker I have had and easy to integrate. Was using two in one system, but bought another amp and split them so that I now have one in each system. Will go back to running pairs when funds permit.
OK. I understand what you mean & agree that the Lore S are on the lean side. I'm thinking of incorporating a sub but have not concluded that for sure. I'm coming from a pair of upgraded Vandersteens that were very full & rich. Unfortunately, they are also very demanding as to placement. The Lore S are much easier to live with & sound good at modest volumes. There's always some element of compromise, isn't there?
Mark
Mark,
You might consider the Boozehound active crossover that's now being offered with the Heils.
I have had my Lores for about a month now. I use them with an 8 watt per channel tube amp and it powers them just fine. All I really have to say about them is that the break in period is very real, they change significantly over time, for the better.
