Tekton Owners Thread
Yes. That's the preamp I have and it's impressive with any of my TPA3116 amps. Very close to SET SQ for far less money. With that preamp plus a $20 TPA3116 there's no equal at triple the price.
FWIW I've owned all the vintage amps such as Scott, Fisher, Dynaco, HK etc. and moved on to modern.
I guess for the money, I could try that out and see how it sounds. I just don't want to downgrade because the Pioneer integrated amp I am currently using sounds darn good.
I listened to a Crown XLS drive two subs and it sounded great. Wouldn't call the Crowns audiophile as they are designed for pro sound use in large venues. With the brute power of a Crown XLS 1500 you'd have to be careful and not overdrive the sensitive Lores.
I could also try this option and see how it sounds, just use my Pioneer as a pre-amp. I would never overdrive the Tekton's just nice to have that power on tap.
Also, I am getting confused on which TPA3116 amp to buy, it looks like there are multiple options. What is the best one to buy that is already assembled? I don't want to have to put anything together. Too lazy. LOL
just that amps will sound better on tektons. dont read anything into it.
it means nothing. only my opinion.
Your opinion can and will differ. and others will have different opinions too.
I guess I am still a little confused. That amps will sound better on Tektons? As opposed to integrated amps? Are you saying that dedicated amps will sound better on Tektons?
Here's what I'd do if I didn't want to DIY a TPA3116.
I'd have this guy ( FleaWatt ) build a custom power amp using the Audiobah Green board or YJ board - he's familiar with both.
http://fleawatt.blogspot.com
And use the Nobsound 12AX7 tube amp with it. If you wanted a less expensive tube preamp FleaWatt would probably build you a YJ 6N3.
These options would give you an amp that is far more revealing with the Tektons than your Pioneer.
HiFiJeff - don't get ahead of yourself pal. Get the speakers, live with them for awhile. If in 6 months you want to try something else, give it a go then. You may fall in love with the Pioneer & Tektons. In the meantime, keep an eye on Bartertown & something may catch your eye. There's no rush.
Finally some good advice. LOL. :D Just kidding.
But really, I do think that is good advice. I already like how everything sounds right now and the ONLY reason I am even looking to upgrade my current M-Lores is the finish. I can't have the satin red in my main living room. I want the BMW Grey Metallic Mirror finish, it's so nice! But since I am getting a new speaker might as well take a step up from the M-Lore.
I might try the Crown option just because it is so inexpensive but I will try the new speakers out with my Pioneer first just to see how I like it.
This is good advice. Too often we get impatient. Giddy with the possibility of new toys to play with. Take your time. One step at a time read, listen when possible, evaluate, and last of all spend money. Try to eliminate as many questions and as much doubt as possible before buying. You will likely save money and lose less hair with this approach.
cubdog
My money is on the idea that the OP will really not see much difference in sound between the Lore and M-Lore. I would invest in a good sub and give the TPA 3116 a try.
Here's a picture of my $20 home-brew TPA3116 sitting atop it's $35 linear power supply. The TPA is driving Frugal Horns which are slightly less efficient than the Lores. The tube preamp on the left really makes the TPA's shine.
I'm running this amp with my Lore Reference. I'm quite pleased with it. For small ensemble jazz it really swings. I do plan on replacing it with a Brio-R soon--but that's because I've been itching to try an integrated with a built in phono pre.
So let me ask you a few questions. One, in regards to the Lore Reference itself. Is it revealing? Clean highs? I really like cymbals and snare drums and so on. I am not talking about bright or harsh, just clean and very detailed. I like hearing the little nuances in music. Then as far as the bass goes, how well does in handle kick drums and such? I like testing out speakers capabilities with some Metallica or Primus. I own the M-Lores right now and am very pleased with them but I heard that the Lore Reference is a little more refined, a little quicker and a little more detailed when it comes to the upper frequencies It look like the specs go from 37HZ-40KHZ. The M-Lore only goes to 20KHZ.
And that is one of the things I love about my Pioneer, it has a really good MM/MS phono stage already built into it. And I really want to get into vinyl so maybe I will save my money and purchase a record player instead. :)
And for only $79.99, I could always keep and use my Pioneer as a pre-amp/phono stage and hook this external amp and see if it is better than the amps in the Pioneer.
