Tekton Owners Thread
I can see why he likes the big SS amps for his speakers. I have used mine with everything from 3 watt 2A3 SET to high power SS. Although they sound good with anything I have tried, I like them best with high power SS.
I recently picked up a very slightly used (3 month old) pair of Lore References from a guy on audiogon. I had a pair of new Klipsch F-30 towers that I had been using but decided to try out a pair of Tektons. I was about to order a pair of Mini Lores but found this pair of References instead for $640, shipping included.
At first they didn't really blow me away, but after some extended listening I'm getting some of the magic I was hoping for. They aren't as efficient or punchy as my Klipsches were, but the detail is pretty amazing and the soundstage depth is much better than the Klipsches. The Klipsches did have a more solid bass response. I sold the Klipsches but did add a small Dayton Sub-800 8" 80w powered sub, just to add a little extension and impact to the low end, and it's worked really well. The sub is set to a very low level, barely audible actually but it's just enough to shore up the bottom.
I'm currently using a Yamaha AX-596 integrated to power them, fed by a Nakamichi CDP or Pro-Ject 2.9/Sumiko Blue Point 2/Parasound ZPhono setup. I'm thinking of upgrading soon to the Music Hall A15.3 integrated to try that out with the Tektons. My room is only 11x11x8, so I don't need a lot of power to get 'realistic' volume levels, especially with these relatively efficient speakers. My Yamaha is rated at 100wrms / channel and it gets plenty loud in there.
Any thoughts on the Music Hall A15.3 and these Tektons? If not that, I've seen some older NAD integrated amps (3150 for example) that should fit the bill?
I found a heavily discounted used Vincent SV-121 integrated (2x50w rms into 8ohm). I read one review that said it sounded 'slow' and 'terrible' with acoustic guitar, but other than that I can't find much about this thing. I'd like to try it with my Lore References...
FWIW, my M-Lores sounded very good with a NAD 3020, but really benefited from a little extra power from my Adcom GFA-535 (using the NAD as a pre).
Related to the other questions about amp/speaker pairing, I'd be interested in hearing any opinions on Blue Circle's CS amp. I have a chance to pick one up, but there's been no talk about it on AK for years.
My Enzo XL's arrived today. I have a couple hours on them and will wait a bit before making a judgement. So far So good. I did order them with grills and they did not arrive with grills. I also spoke with them about the Clarity Cap upgrade and I do not know if that was done. I have a feeling they sent out the red pair that they had. Looks like I need to remove a woofer to see if the cap upgrade was done.
Initial impressions are good. Finish is good. Im liking what im hearing so far!
Well, I'm about to find out how the M-Lores do with lots of wattage. Today my Class D Audio amp arrived. It's 300 wpc into 8ohms, 600 in 4. Way more than these will need; should be fun :)
I am looking forward to hearing your thoughts. I have my M-Lores set up with a SS 125 watt per side amp, tube preamp, and a 12 inch servo sub. I can't turn the preamp up past 10. So much headroom.
The speakers just seem to like the power.
If you don't mind me asking, what amp did you get? I've had my eye on Crown's XLS Class D amps for a while.
I got the. Class D Audio SDS 470C. It's a smaller company in LA that does Irs2092 based designs. Sounds awesome so far. Really smooth compared to other class d amps I've tried that are very analytical. The amp is detailed while still being easy on the ears. So far so good.
Don't worry you will get your grills.
Eric's first priority is to get your speakers to you.
The grills will follow but it will probably be a few weeks.
Just sit back and enjoy the music.
It is going to take like 40-50 hours for them to really open up.
On Wednesday I won an auction on Ebay for a Music Hall A15.3, new but open box, for $370 with free shipping. I should get it at the end of this coming week. It will power my Lore References. Will be fed by my Nakamichi CD player or Pro-Ject 2.9 Wood Classic TT with Sumiko Blue Point 2 cart.
The Clarity Caps are installed and the grills are on the way. These are incredible speakers. Best I have owned. Truly remarkable at any price point.
One thing I've noticed with my Lore References is what seems to be a sort of accentuation in the presense region, which rears its ugly head mostly when listening to female vocals, making them sound 'screechy' or shouty. I don't know if its the breakup of the upper frequency response of the relatively large 8" midwoofer, which isn't controlled well enough with the existing crossover network, or if it's a room anomaly (I've been experimenting with different placements and it hasn't seemed to help that much), or if my Yamaha integrated just doesn't play that well with these for some reason. My Music Hall A15.3 is supposed to arrive Friday, I'll try it out and see if it helps or makes this worse. Other than that I'm enjoying them very much, especially the detail retrieval, soundstage depth, imaging, and generally the ability for them to just 'disappear'.
Generally, older recordings that aren't mixed as 'hot' as a lot of newer stuff doesn't seem to be as much of an issue, so maybe it's partially just them being ruthlessly truthful.
Anyone else have this 'issue' with their Tektons? It should be noted that my listening room is small - 11x11x8, with carpet pad lining every wall (and floor) except the front wall behind the speakers. So not an ideal room by any means but right now it's what I've got.
After speaking with Eric regarding the entire Lore line-up I decided to go with a pair of Lores.
I am coming from a pair of revamped Klipsch La Scalas and an OB design using Hawthorne Silver Iris drivers.....
I hope the Lores will best both of these...we shall find out; delivery should be late next week.
I haven't noticed this issue with my Lore 2's, although you've made me curious. I've listened to Fleetwood Mac, Cowboy Junkies, and Patti Smith recently. I'll have to mine the record collection for more female singers and report back.
-Dave
-Dave
Thanks Dave. After doing more listening last night, It seems that they're just a little forward in the upper mids in general, maybe not as 'warm' as I'd like them to be. But I'll invest more time experimenting with placement and trying other amplification components. I'd like to fall in love with them, but it hasn't happened yet.
Music Hall A15.3 arrived and installed. Haven't used it much yet but it seems to have a great phono stage! I had temporarily swapped in a 1981-vintage Pioneer SX-5 receiver that my grandma gave me, and that had warmed up the lower mids a bit in a pleasing way (and had a surprising amount of slam for 'only' 30wpc) but the phono stage in it was only satisfactory (missing bottom and top end extension and smoothness). The A15.3 has a slightly more dry and detailed sound than the old Pioneer, but then again I haven't broken in the MH yet. It sure looks nice with my Nak CDP.
All in all I think it should be a good match for the Tektons. It certainly has plenty of power for realistic listening levels in my small room.
