FWIW,
lbs = pounds
dbs = decibels
Gotcha.....vision not what it used to be I thought that was 98 lbs there! Yes the are 98
dB efficient. Never seen it as
"dbs".....As to SE amps, they will play I'm sure given the efficiency, never been a flea amp fan. That said, I would like to build a SE 45, (had one but sold the project before finished) to drive into a Pass F4. Still have F4 boards, but lost interest when BA3, F6, and M2 Pass amps became available. Driving the 45 into a F4 basically gives you the single ended glory of the 2-3 watt 45, but coming out of the F4 its upped to 25 watts. Its an unusual amp with no gain, so it relies on your front end for the gain. Passive volume in front of SE 45 into F4 is supposed to be quite special.
Eric seems to like higher powered SS amps (200+ watts) for these, I am using much less...The BA3 pass amp with 31 volt rails will do 50 watts Class A into 8 ohms. I have a balanced mono block (BBA3) in the parts stage that will deliver 100 watts Class A that should get interesting. This evening I am using a Pass F6, 25 watts into 8 ohms, 40-50 into 4 ohms power amp, seems to like it fine.
I have read where others used SE amps on Tektons with positive results. They play efficiently enough, but also seem to handle high volumes without strain as well.
I think one more night of play should have them mostly broken in. I did not notice that much of an improvement this evening, but last night over the previous night was a large jump, especially Bass wise.
There are AK people in the area, Jaymana for instance, that have a few SE amps to try, I will have to talk him or another member into hauling one over for a try. Sure it will be interesting.
Do you drive those open baffle speakers with SE?
Russellc
