Help!!! I am so confused now about buying an amp.I have orderd the Double Impacts and am now looking for an amp and preamp to build a great system. I have read that the Tekton speakers were designed for SS with a lot of power, someone mentioned this is how Eric likes his setup. I found an amp that really looks nice, the Emotive XPA Gen3. These are the specs:
550 watts RMS per channel; 20 Hz - 20 kHz; THD < 0.2%; into 4 Ohms.
Power Bandwidth (at rated power; 8 Ohm load)
20 Hz to 20 kHz (+ / - 0.1 dB).
Broad Band Frequency Response
5 Hz to 80 kHz (+ 0 / - 0.15 dB).
THD + noise
< 0.005%; at 100 watts RMS; 1 kHz; 8 Ohms
Signal to Noise Ratio (8 Ohm load)
> 117 dB; ref FTC rated power; unbalanced input (A-weighted).
> 91 dB; ref 1 watt; unbalanced input (A-weighted).
Emotiva also makes a nice preamp, XSP-1.
Now I am hearing about Decware amps. They are 2 watts per channel and are supposed to run a pair of speakers. This is all new to me. Can someone who owns Tekton speakers especially DI's what they think? I thought buying a house was hard!!! Thanks
@Page { margin: 2cm } p { margin-bottom: 0.25cm; line-height: 120% }
Tekton speakers do not need a lot oomph to be driven because they are quite sensitive. You can certainly buy as big an amp as you'd like, but it's really not needed and it will not do anything to improve the sound quality. Some speakers need tons of power like Harbeths to sound their best, but Tektons couldn't care less about raw power. They need quality and refinement in amplification which gives them great flexibility and versatility. My rule of thumb is this: Spend at least as much on the amp as you did on the speakers and you will enjoy both. As far as amps go, power <> quality unless the speakers demand it to be driven properly. The more important aspect is impedance because both components should be matched in ohmage. Some people say it's OK to hook up a lower ohm amp to a set of higher ohm speakers, but I don't believe that is a good idea as that could degrade the sound quality. Perhaps for certain setups it's acceptable, but for a high-end home stereo both should be either 4 or 8 ohms (or any other matching combo). Also, going with lower ohm speakers and a higher ohm amp would absolutely create a huge problem as your amp would sense that the speakers are resistors and not a sound producing component.The amp would start to overheat and after awhile, well you get the picture. Failure to follow this rule will result in damage, even permanent destruction of equipment and possibly start a fire so it is really important to pay attention to this. The good news is that many modern amps can handle both resistance settings, but if you are an old school amp lover like myself, paying attention to ohm ratings will pay dividends down the road as they are usually preset to handle only one.
As for the brands, that's really up to you and your budget. I personally like Naim because of their longstanding tradition of making quality, durable amps. I have never heard of a Naim amp dying when wired correctly no matter its age. And yes, they are still made in the UK just like the first one that came out in the 70's. They are not inexpensive, but they will outlast both you, me and probably a generation or two after us. I'd stay away from Chinese assembled amps even if they carry a brand name because their quality control is not on par with British, American and Canadian made gear. Chinese are after high volume/lower price per unit production, not uniform standards of quality. You may be lucky and end up with a good one, but you could also be unpleasantly surprised if your amp burns out for no particular reason. The same is true for tubes in case you decide to go that route. Russia makes the best tubes available, imo. Based on what I've been reading, the DI's and a good tube amp are a great combo so I'd definitely spend some time researching those.
For other brands, Blue Circle Audio makes really good amps, but they are almost like a boutique offering since everything is made to order. Yes, they are quite expensive, but quality always is. I also like Bryston (so confident in their stuff, the company gives piece of mind through their unbelievable 20 year warranty), Cary Audio (highly rated and USA quality made stuff), Rogue Audio and Creek (pre 2004 models only as those were still made in England. Since that year, Creek unfortunately moved its operations to China in order to cut cost).
That is my rather long 0.02 on this subject. There are many more options out there so do some research and compare different models. Good luck!
