hakaplan said:I have only used the HiFi News record to test for resonance, i.e. tonearm/cartridge match, and I can tell you that the test tones frequencies are inaccurate. The ones on the Shure obstacle course record (Era IV and later) are accurate.
No, it's the new version. For cartridge alignment it might be fine--but the test tones for resonance testing are definitely off.REDone said:Is that the new version Hi Fi News?? It has been reworked by the "Cartridge Man" so I expect is better now
But Thanks I will investigate the Shure
markd51 said:Era IV means later intinerations-versions of the Shure Test LP.
One difference of the Cardas Test LP, there's a demagnetizing Track for MC Cartridges. Even though I have this LP, as well as the Hi-Fi News, and Shure Test LP, I'm not so sure how well the demag sweep is, but it's doubtful that it in itself can be a detriment. Mark
REDone said:As an experiment I did try damping the arm with a thin ring of blue tack 1/3rd way down the arm & adjusting the tracking force to 1 g .. but it was actually worse.
UpsideThe Head said:Not a good idea. I have seen a thin wrapping of teflon tape around 1/2 of the tonarm used by some folks with good results though. Its much lighter and damps well.
REDone said:1V Shure Trackability Test TTR 115 ... It arrived before Xmas but just had the chance to play side 2
Playing this on a standard Connoisseur BD1 with Shure M95
I also received the right alignment protractor so as far as my eyes tell me eveything is as it should be & the sound has been improved a lot
Thought I would report back on findings
Interesting to play as it showed a very very slight imbalance between volume on Left & Right Channels & my amp does not have a normal balance control .. (it is underneath ) Nor does it have any volume stages marked out.. so I have a little fiddle to do (assuming my ears are not the problem)
Tracking force set at 1 gram on a shure M95 Encore .. On side 2 the resonance test showed the Connoisseur arm capable of playing the whole of track 5 without jumping.. oscillation started at 8Hz, was worse at 10Hz & got better at 12 Hz (equating to 8Hz) .. I would be interested to compare results to what others have found on their decks / arms
Still have a slight annoying sibillance so I am about to adjust tracking force to see if there can be any improvement that way.
hakaplan said:Tracking force for most high end M carts, including the M95 is 1.25g--that may explain the silibants. Also, I always considered the resonant frequency to be the peak, in your case 10Hz. Am I wrong?
I'll test the M95 on my Pioneer (S-arm) decks this week and report back. Your tonearm looks like lower mass and should be a good match with the M95.
