Quadman2
Lunatic Member
What gear is suggested for a better result?
So far you have described your gear as "Two set ups" (intro post), a later post mentions a "budget amp", and the other day, "a cheap Radio Shack and a "custom made set" that you put together.
That other set you "put together" was it a kit? Or a refurbished unit? To date you've had several suggestions, one by Harvester and his Technics set up. If you look back just recently there's a great thread on whether "tone controls" should be used", wherein different gear gets tossed around in the discussion of this sound issue.
When you suggest "better gear" are you wanting to go with: modern or stay with vint? Much of your future buys will be determined by the depth of your pocket, what quality you want to strive for, a lucky chance of encountering "better gear, or what the SO says. Sometimes the last variable is the most critical.
There's tons of info on AK wherein discussions carry on, as each person has a personal bias what is good or bad results based on what they've had in the past. I've got my own preference: Brit based (Quad), but that's just my personal take. For others it's gotta be Kenwood, Denon, Marantz etc.
Others can't get a handle on what you have as that second unit that may produce sound great sound.
In the end, it will be your own ears that will decide what you think sounds best. The testing devices may indicate what's going on, but the other variables such as: speakers, sound environment, amount of power, etc. have to be taken into account as well. Cables for me is one of the lesser important links in the search for better sound, as speakers and sound source are more important... but there are others who don't hold this belief. Sound is a very subjective element in this hobby...for most.
What is better gear? After you share what you've got, there are others on board far more knowledgable than I, who can make some great choices for you to follow up on.
Good luck on your quest, and let us know how it went.
Q
