Hi all
Recently I bought a bunch of different Russian and Soviet 6922 tubes. Some are Electro-Harmonix, some are Sovteks (under the RAM label), some are 6N23p Reflector. Since these tubes are scarce now because of the war, I wonder if what I got were some not so perfect ones. I have two tube testers, both calibrated: Eico 667 (so-so, I know), and B&K 747 (more serious). All of these tubes measure bad or borderline in Eico; in BK their behavior is strange: after a few minutes they measure bad or borderline, with needle going lower. If I hold the merit buttons for a while, the needle begins to go higher, sometimes into green (good) area. After I used RAMs in my ARC PH3 phono stage for a few hrs, and tested right away, they tested nearly good, but after a while went down. What is the deal with these tubes? Anybody has similar experience? The store I bought from told me that my testers are no good for testing “modern” tubes. I never have similar problems with my Amperex Holland, or a couple of cherished Mullards.
