Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Yes, those internal resistors (especially the 500Ω one) and the embedded diode will throw off the B-E (nominally around 1.2V) and E-C measurements, respectively. And yes this diode-checker test is only a quick go-nogo test, it doesn't test the transistor's main ability: to amplify. (As an aside, there are those cheap multimeters with transistor check function. You still need to do the diode check of the junctions before you can trust these transistor checkers.)
Anyone seen a germanium darlington? Not sure if one exists...
