Looking sexy! Finally, something is emerging....
Great stuff, guys. Thanks Wigwam, for the photos. I've started a new folder for this project.
rick
Thanks, Rick. Good news, folks, about that transformer. You see that big honking toroidal transformer sitting there? Well, it turns out it's even a better deal than Antec advertised.
You see, this is an Antec 3T275. Here's a link to the specs:
http://www.antekinc.com/trans.html
http://www.antekinc.com/AN-3T275.pdf
Now, in the pdf file you see above, it gives this rating:
I/P 115 V
I/P 115 V
O/P 275 V
O/P 275 V
O/P 6.3V 4 Amp
O/P 12.6 V 3 Amp
But that's not what it is.
It is this:
Notice - no 12.6 V O/P. So Squidward called them up and it turns out that the real specs for this transformer are 6.3 V @ 5 amps and 6.3 V @ 5 amps.
At least, that's what we think at the moment.
Don't rush out and buy the transformer yet - we're testing.
I had a great time at Squidward's house on Sunday. Pakprotector stopped by and we had quite the chat-up. I learned much from both of them (thanks, guys).
When I left Squidward's house on Sunday evening, he was still soldering the heaters up - but he was planning to see tubes glowing by Sunday night.
So that's where we're at. If the story about the transformer is true, it's the best deal ever on a power transformer, and it's about to become their number one best seller.
I will shut up now, share a few more photos, and let Squidward talk.
He did all the work. I took a few notes, took a few photos, and generally got in the way.
We are going with a tube rectifier design - you see one of them sticking out here. But notice - Squidward, Kegger, and Pakprotector (I think it was them, I could be lying accidentally) came up with this awesome idea of wiring in all four sockets you see - they can test a number of tube rectifier designs in the prototype, and go with whatever works the best, be it one tube, two tubes, or what-have-you. So this is for experimentation.
This part is uber-cool. This is Squidward's brainchild. This modular piece will be host to the compactron tubes we're talking about for this design. But, with the awesome modular design of the power section, this amp could support innumerable tube topologies, using any number of different tubes. 300 volts and a bunch of amps for the 6.3 means lots and lots of different choices could be made - and with this modular design plate, you could have fun experimenting to your heart's content.
Here's one more shot of the overall layout. Note that Squidward intends to run the heater power down one side of the chassis, and the tubes to the output transformers down the other side. This should keep spurious noise to an absolute minimum.
