Glassweights
Compulsive about tubes
Crap Out
Ok,
I opened mine up to see what I did to fix it.
I jumpered both positions on the switch together and tied them to the lead that I thought was for the most windings ie high power!
I did many scientific measurements of the coil and the switch first.
Pretty sure I ended up proving something was wrong with the switch, but this seemed to fix it.
If this had not fixed it I was just going to wired it always on, because, I have not used mine much at all so I felt I had not burned it out or anything.
It would have made more sense to try one or then the other, but I bet it was the half power step that is bad since you always transition through it. But I could not figure out why that would make the fully depressed position not work??
Now it works great fully depressed.
Ok, I admit it, I have no clue why this fixed it
Good luck!
Dan
Alright Guys...What would cause something like this to Crap Out??
Ok,
Good luck!
Dan
