For the past several years I’ve been using a Pioneer SA-9500 II integrated amp for vinyl playback and I have grown fond of it and its ample cartridge loading options (both resistance and capacitance). Lately I’ve been thinking of giving a MC cartridge a try on my Empire/Linn hybrid, so in preparation I purchased an Onkyo P-360RS pre-amp for its MC cartridge capabilities. After servicing the Onkyo I gave her a whirl with my Ortofon OM /200NE cartridge. I immediately noticed much improved detail with this pre-amp V/S the 30 year old 9500 II, however it sounded a little “off” to me. This led me to wonder, just how critical is proper cartridge loading and could that be the source of the problem? With these questions in mind, I set out to learn how to add capacitance to a phono stage. After AK member catman was kind enough to clue me in as to how it’s done, I was off to the races! I bought two RCA “Y” adapters, some cheap male RCA plugs and a small variety of capacitors (51pF, 100pF, 150pF, 200pF, 250pF, 300pF and 350pF). I soldered the caps to the plugs and began to try each cap in successive order until I found the sweet spot. The factory recommended capacitance loading range for Ortofon OM carts is between 200-600pF (depending on the stylus to varying degree). The Onkyo has a factory capacitance loading of 220pF (thanks dr*audio). I found that the Ortofon sounded best to me with an additional 100pF capacitance (a total of 320pF). I’m here to tell you the sonic difference between 220pF and 320pF with this cart is nothing less than amazing to my ears!
This leads me to wonder why I haven’t seen more posts here regarding the importance of proper cartridge loading. I just happened to stumble upon this important adjustment by circumstance; I think it would benefit our members here a great deal if this topic were discussed here more often. What do you guys think?
Bill.
