bobdod
As I've written in a separate thread, I've taken possession of a Japanese market B-2. My goal is to give it a bit of a refresh and take care of any known trouble spots. I have no history on this B-2, and I have not powered it on, so don't know if any problems exist at the moment.
I was told by a few folks that it would only take 15 minutes to pull and test the vfets. Having no history on the amp, I figured that needs to be the first step, as vfet replacement would be a likely project ender for me. After getting into it, and getting the vfets out, I can see how one can do it in 15 minutes. I however, had never been in a B-2 until today, so for me it took about an hour. I made sure to prepare and set everything up ahead of time so as not to mix up the devices. After testing them with my multimeter, per echowars' instructions, I think they are ok. Or at least based on the testing I could do without more serious equipment, I will say for now that they are ok.
First look under the hood. A bit dusty.
A look at the power board. No warping or signs of heat damage.
A look at the filter caps. No signs of leakage or bulging that I could see. I think I'll replace them anyway, but I think they may test good still.
My vfet container, with numbers so that I don't mix them up.
Close-ups of the devices before removal.
Removed devices in their storage container
I have a feeling that the vfets on one side were replaced at some point. Several of the bolts holding them to the heatsinks were missing washers. They also have numbering written on them, whereas the devices on the other channel do not. The numbers are 6, 39, 7, and 33. One of them also has marking on the back, that say "IR" and something else. The device with the marks on the back had a little lower resistance measurement between drain and source (1.3ohm, where most of the others were around 2ohm). It tested in line with the other vfets otherwise.
Just checking in!
