Have made a little progress on this, but not smooth sailing unfortunately. All items in this post were done with VFETS not installed. I slowly brought it up on my variac/DBT. No DBT issues, but not all is good:
The good:
- voltage between B+ and B- (red and white on the VFET boards) is ~115V on both channels, as expected.
- voltage between B+ or B- and E (on VFET boards) is ~57.5V (half of B+ to B-) on both channels, as expected.
- +85 measured at 85V, as expected.
- no 2SC458 LGs (outhouse style) found on the power board.
- I have tested all components on the Right driver board (the one that was previously repaired) and all tested good.
The not good:
- Unit comes out of protection, and left relay clicks, but right does not.
- the -85V is running at -94V, with VR202 turned all the way down. I have confirmed that the trimmer is good. I am not sure if something failed during the reforming w/ variac, or was an issue previously. I took readings on +85 and -85 each time I increased voltage and both were solid up to about ~60V. When I took measurements at line voltage (100V) the -85 measured high, and could not be lowered with VR202).
I have not had a chance to do more diagnostics on the power board yet. If anyone has any initial thoughts on what to check, I would appreciate any guidance, either on the forum or privately).
