But for now I have that Bugle2 sitting here
It was something I was planning to do this weekend or so.
If you build your Bugle2 pcb with the mods that Oranda listed up pages ago, I think your going to be very happy with the results. Mind the fact that choices of opamps, and the c4,c5,c6 caps will make a big difference with overall sound quality/enjoyment. I mentioned it before that adding in the Takman metal film resistors (REYs) where possible also added a bit more transparency in the hf. The Takman metal film REYs were recommended by Oranda and I was so skeptical on my first build that I didn't use them. I'm a big skeptic by nature. Totally eating crow afterwards so on the 2nd build I went full out and used all of the best caps and resistors that had been tested out prior. I'm a slow learner but the results don't lie. But it really depends upon your system and your ears, and how well you can setup a cart.
For a small investment, about 50 bucks, I purchased a Schiit SYS Passive Preamp Volume Control & 2-Input Switch. There is absolutely zero circuitry in the SYS other than the rca jacks, the input 1 or 2 switch, pcb and the volume control potentiometer. Basically adding a volume control from the turntable directly to the power amp. It is the most transparent preamp I've ever heard btw. So my thoughts were to see if the first build versus the 2nd build made any difference. Before anyone doubts it, like I know some do try and argue, that's $7k of table & cart, into a $250 diy phono preamp, into a $5k amp. So I think the chain is solid to do the comparing of apples to apples. Took out the T+A P1230 preamp out of the chain bc it does have its own "sound" even though reviewers have said that it was the "most transparent" preamp they've ever heard.
Both builds used the exact opamps starting with the opa2210 in U2. First Bugle2 build was more of a budget build with only one pair of REY resistors, CDE silver micas in C5, and cost friendly caps in C4,C6. 2nd build had 9 pairs (maybe 10) of REY's , Charcroft Silver Micas, and premium caps in C4 & C6. Swapping for some A/B testing between the two builds and using just the SYS for volume control. There is definitely a difference between the two. 1st Bugle build has a little less detail and overall a little less of the lifelike presentation when compared, but it has a very balanced sound with great low end. The second Bugle build with $50 more in premium caps & resistors definitely & immediately had more detail, air, and hf sparkle. Worth the extra $50? Absolutely! It's hard to unhear the openness and extra detail. So much so that I put away the first Bugle build and never have looked back.
Jim's design is small, concise with short paths between to help keep it quiet. No smd bs to have to deal with so just a basic soldering iron will get the job done. Cost effective and just brilliant. Shout out to Oranda for starting this thread and recommending the Bugle, and all of the work/testing with the mods. Shout out to Jim for designing such a wonderful phono preamp. I honestly don't think it can be beat for the price and ease of the build.
But now
@knotscott has built a Hagerman Cornet I'm very tempted to build one and compare. Can't imagine topping the Bugle2 build but that tube magic and reviews are drawing my attention.
Let us know what you think once you complete your build!
