Hello,
I am considering building the Bugle3. Looking at opamps for U1:
OPA2192 has a very low (the lowest)
Bias Current: ±5 pA ..... that's picoampere!
OPA2210
Input bias current: 0.3 nA or about 100x worse?
Has anyone tested OPA2192 at U1?
PS. Forgot to mention; Oranda has tried many different opamps in the U2 position. Many more than I have, perhaps 10-12 different opamps. I have tried 5 or six different opamps in U2 and many others in u3 and u4 positions. The opa2210 was recommended by a TI engineer from Texas Instruments involved in opamp design. It produces approximately 6dB lower noise floor than the original opamp used in the factory bugle2 and bugle3. That’s a big difference. Ask Jim H. about it as he measured it and found out the results.
Also, I tested it out with mm and mi carts and it beat out all others when compared. I think it is the lower noise floor. Do you have an opa2210? If so it would be really nice if you could give us some feedback on what you hear when you build your Biugle3.
A lot will depend upon your system, your table and cartridge choice. The better your system, the easier it will be to hear the differences.
I see you mentioned the Wyn model preamp. I have 3 or so pcb’s for that build. But, after reading a bit about printed circuit boards, their design, and phono preamp design theory, I feel that Jim Hagerman’s designs are very concise to keep noise/rfi low. Other engineers like the ones at high end audio companies also talk about keeping their designs very concise w short paths as possible. It’s a big part of of T+A design theory as well as others.
I decided not to try the Wyn build because it is quite large and several boards are used depending upon what you want to incorporate.
Couldn’t be happier with the Bugle 3 build and I dare say that it would take something closer to $1.5-2k to find something that surpasses my current build.
Hopefully you’ll get some feedback from Oranda who I believe will be busy for the next few weeks before he gets a chance to respond.
What capacitors do you plan on using for C4,C5,& C6? I highly recommend the Charcroft Silver Micas. I have 2 working Bugle builds and a switch to A/B them. One has the Charcroft Siver Micas and one has another brand. IMO it is the best choice for C5. It was a recommendation from Oranda as well and proved to be an excellent choice.
I wish Jim would build perhaps 10 maybe just offer custom built MC-4 or Bugle3 w the same caps,opamps, and REY resistors and sell them at $650-$850 or so. Would be very much worth it. Would love to see some reviews on one of these.
