The switch explanations/settings.
Above is the translation of the control socket wiring to the switches. It is recommended that the wires be labelled as shown for wiring to the switches or at least identified in a known way. Note that the internal node names in the circuit (as shown to the left of the socket) are not necessarily the same as the names on the wires.
As can be seen the IP stage 6dB extra gain switch shorts the wires labelled IP6dBR/L together using a double pole switch.
Similarly for the OP stage 9dB gain, where the OP9dBR/L wires are shorted together by a switch.
The warp/stereo/mono switching either shorts the WARPR/L or the MONOR/L to the FILTIPR/L for WARP or MONO or leaves the connection open for STEREO.
Again, a double pole switch or two is needed.
Two are needed if the mono/warp choice is to be made by one switch, then the mono(warp) or stereo choice is to be made by a second switch.
One is needed if the switch is three way, with the central setting being No Connection for STEREO and the other two being MONO or WARP.
There is also a POWER on off switch. It is a DPDT switch. The first pole is for opening or closing the AC line to the power supply (PSW1), and the second is for disabling or enabling the output relay coincidentally with the opening or closing of the AC switch (PSW2). The switches are therefore wired opposite in phase.
When the power is turned on there will be a delay of about 30s until the outputs are enabled.
In addition there is a separate MUTE switch. This is in parallel with PSW2. It is recommended that the mute is activated any time a MM/MC selection or a WARP/MONO/STEREO selection is made.
When the mute is activated the output relay is turned off. If the mute is deactivated the relay will be on after a delay of about 30s.
